Drivetrain JB+ with DashCommander
Old Nov 6, 2013 | 07:08 PM
ClubmanRob's Avatar
ClubmanRob
Can I use a OBD 2 Y-Splitter and connect the BMS JB+ piggyback system with a PLX Kiwi BT Interface? I would like real time info from DashCommand while having my JB+ module running as well. Thanks
Old Nov 6, 2013 | 07:32 PM
RoyalCooper's Avatar
RoyalCooper
The JB+ does not attach to your OBD II port... the CAN tool that can monitor it does. If you're monitoring via DashCommand there wouldn't be a need to duplicate that with the CAN tool, thus the port would only be occupied with your PLX Kiwi BT Interface.
Old Nov 6, 2013 | 07:34 PM
Mcameron's Avatar
Mcameron
are you talking about the BMS CAN tool (The device that allows you to hijack your gauges) or the actual JB+ (the bit that gives you more power)?
because the JB+ doesnt plug into your OBD2 port, it plugs into your MAF which is located on your airbox.
Old Nov 6, 2013 | 07:37 PM
ClubmanRob's Avatar
ClubmanRob
Duh! Thanks guys, I was confusing them. Thank you both for the info.
JB+ module should be here ina few days. Ordered the DDS Intake as well. Hope they work well together.
OutMotoring
Nov 16, 2015 07:04 AM
BackroadRunner
Sep 29, 2015 08:06 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Colt45Magnus
Sep 23, 2015 07:38 PM
Shane Wendel
Sep 18, 2015 06:18 PM
