Drivetrain Thanks to way motor works for fast shipping
Old Oct 29, 2013 | 07:44 PM
d454brisson's Avatar
d454brisson
Ordered a Invidia exhaust sunday and it showed up Tues morn. Just finished putting it on the car and other than breaking a clamp bolt with an air gun (my fault) I am extremely pleased.
I used some of the posts from this forum to help fitment, although I think the tips are a bit close to the plastic. I may drop the hangers with spacers or try to put some reflective shielding on bottom out of view.
I am waiting on a panel filter and stiffer blow off valve spring from Alta. After that I am not sure what I will do next.
2010 Mini cooper S camden edition
Old Oct 29, 2013 | 08:01 PM
maxmini's Avatar
maxmini
You are correct. I went by my local install shop on Sat and a friend of mine was replacing the rear plastic and modifying the mounts for clearance .
Randy
Old Oct 29, 2013 | 08:10 PM
Melangell's Avatar
Melangell
I had a small extension welded on:
Way is great to work with.
Old Oct 29, 2013 | 08:46 PM
maxmini's Avatar
maxmini
That should do the trick. You have to wonder what Invidia were thinking when they signed off on the design.
Way knows his stuff.
Randy
Old Oct 30, 2013 | 08:04 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Thanks we ship as fast as we can, next time give us a call about the other parts as we can help you out there too. We don't use those panel filters as we've had too many issues with the oil damaging the expensive MASS sensor. We only recommend the Dry Panel Filters.
Old Oct 30, 2013 | 09:18 AM
NewCooperFanatic's Avatar
NewCooperFanatic
The tips do sit close to the rear trim, but I can say 30k miles and no melting or discoloring whatsoever. Just rotate the center pipe to get the tips centered.
It took me a fair bit of fiddling but I finally got it dead center!
Old Oct 30, 2013 | 05:22 PM
d454brisson
Thanks for the filter info, I will be contacting you shortly for proabbaly a turbo upgrade ie JCW version or the like and ECU tune to support it as I do more research on whats possible and fairly motor safe.
Regards.
D.Brisson
Zettinger
Aug 25, 2015 04:04 PM
Emnotek
Aug 13, 2015 05:47 PM
minipopkart
Aug 13, 2015 05:22 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
