Drivetrain Forge Blow Off Adaptor For Cooper S Turbo
Old Jan 22, 2014 | 06:55 AM
  #26
Mini R56's Avatar
Mini R56
Originally Posted by InjectedGT
I do understand how these things work and on these cars, the MAF is not the sole provider of air intake information for fuel adjustments. Venting the excess compressed air to atmosphere on the N14 should not cause an issue. If it's causing an issue for some people, that's odd to me because again, all of our motors are controlled and monitored the same and there are plenty of people without issues. If these cars ran solely off a MAF like an old MR2 or something where you KNOW you're going to mess up the air/fuel mixture by venting to atmosphere that would be one thing. But these companies such as Forge came up with this part knowing that it wouldn't cause issues.
And yes, the only difference between the air recirculating and being vented IS air/fuel metering. What else would the recirculated air possibly benefit? This has nothing to do with the operation of the factory valve, diaphragm issues, or anything like that. It simply spaces the stock valve back, which still works as it did previously, the air is simply rerouted.
yes your absolutely right in that respect... however... the computer (save your case) knows that its not recirculating correctly and gets fussy... as far as damage goes or a bad A/F ratio, well theres is none, the computer is smart enough to keep a correct A/F using the MAF like you said... your not gonna harm anything. But a an overwhelming amount of us that tried it got a CEL and Limp Mode (No Boost)
Forge manufactured these for the MINI's because of their overwhelming popularity in the VW/AUDI world (Sound awesome for $40 why not right)... their computers are different from ours and do not throw CEL's.. so you can just put one in a VAG car and have zero ramifications for it (some report a slight power loss and take it out, once again its not a MINI so Minis react different). They use an almost identically DV system, (Which is why you can take their upgraded internals and swap them with ours)
Old Jan 22, 2014 | 07:02 AM
  #27
HorseWithNoName's Avatar
HorseWithNoName
Wanted to know the part number for the n18, but realized guys are talking N14's only.
Enjoy your rides..
Old Jan 22, 2014 | 07:11 AM
  #28
InjectedGT's Avatar
InjectedGT
Enjoy your rides..
The part in question, in this thread is here:
http://www.waymotorworks.com/forge-b...r-s-turbo.html
It will work on either N18 or N14 as the turbo and diverter valve are the same(aside from the N18 having a stronger diaphragm on it's diverter valve).
Old Jan 22, 2014 | 07:13 AM
  #29
vetsvette's Avatar
vetsvette
Moderator
Enjoy your rides..
Take a look at this. FMDV60R for N18.
http://www.forgemotorsport.com/conte...oduct=FMDVR60R
Old Jan 22, 2014 | 09:04 AM
  #30
HorseWithNoName
Thanks...
Old Jan 22, 2014 | 09:49 AM
  #31
MikewithaMini's Avatar
MikewithaMini
I've had it installed for over 6 months on my '08 without issue. I've been thinking of putting the stiffer spring in just to see if there is any difference between the two, just out of curiosity.
Old Jan 22, 2014 | 03:03 PM
  #32
Tabintab's Avatar
Tabintab
Now then, thats the exact thought I had. I did not want to pay silly prices though. Anyone know where we can get a stiffer spring without the silly cost?
Tab
Old Jan 22, 2014 | 04:31 PM
  #33
nine5raptor's Avatar
nine5raptor
$20 shipped over Christmas for me. Worth not having to search all over and try multiple springs. My time is worth more than $20.
Sent from my XT926 using NAMotoring
Old Jan 22, 2014 | 05:16 PM
  #34
RAYGUNZAP's Avatar
RAYGUNZAP
I've had a Forge re-circ valve on my car for 8 months… No codes! Smooth sailing!
Old Jan 22, 2014 | 06:49 PM
  #35
Systemlord's Avatar
Systemlord
The re-circ valve wasn't an issue for some, it was the adaptor that vents to atmosphere is where the topic get heated. Some have issues with this adaptor while others do not.
Old Feb 11, 2015 | 09:59 AM
  #36
mydime13's Avatar
mydime13
adapter n18?
Originally Posted by TonyCheckraise
I had one of these installed on my 2012 MCS along with the NM intake. The sound it puts out is loud, a little bit louder than running just the intake alone. The main difference between the two was that the sound was just a tad different in tone. Performance gains were non existent, but it did not throw a CEL on the N18 engine.
I had it installed for quite about 5 months. The sound got on my nerves, a bit too much for me. I just recently removed it and replaced the entire diverter valve with Forge's piston style recirculating diverter valve kit for the N18 (P/N: FMDVR60R). This kit with the NM intake is much quieter than even a completely stock setup, and I enjoy it.
I have a n18 engine. Did the adapter work? I heard and read it only works in n14 engines...
Old Mar 31, 2015 | 07:40 AM
  #37
theUnderDog13's Avatar
theUnderDog13
Since this topic was mentioned here, I'll ask for opinions.. I have a 08 S manual, n14. I installed the forge adapter and the alta spring at once. I loved the sound and the spring felt a noticeable difference in retaining boost between shifts. No CEL's although, I am experiencing a chirping noise if I accelerate quickly. The Alta directions simply states if it has this chirping/fluttering sound, reinstall it because the BOV/spring may be sticking but it doesn't say what to look for. Any ideas???
Old Mar 31, 2015 | 08:27 AM
  #38
Euler-Spiral's Avatar
Euler-Spiral
Could it be variability in the sensors? I have been thinking of going for a Mazda map sensor same series just more range these are OK Peirberg stuff, add in that you have an MAF and Diverter and crank case breather, maybe you get an addition of minor errors. If two people with the Diverter one with trouble one without meet up maybe you could swap sensors and check out the systems side to side. I might ask Forge to send along a rep and get a solution. Note differences in ECU's even same series could have different batch parts a friend who takes them apart doesn't think they are very fast to start with.
Old Mar 31, 2015 | 08:37 PM
  #39
Roxspin72's Avatar
Roxspin72
Not sure what you mean by chirp/flutter?
I do know that if I accelerate aggressively and shift at say red line, I will hear a chirp... Only Chirp, No Flutter.
According to my previous data logs, it seems I am maintaining boost, dumping via Diverter Valve (DV) and immediately building boost at completion of shift.
Flutter would indicate a torn diaphragm in the stock DV. It can also be experienced w/an aftermarket DV, due to a seized mechanical DV piston from lack of grease/exposure to dirt & grime, etc...
My Stock DV w/Alta spring has been working with no issues past 6-7mos. If I start hearing the flutter, end up in limp mode, or start dropping boost, I would immediately begin with an inspection of the stock DV diaphragm or aftermarket mechanical set-up.
Old Apr 1, 2015 | 11:23 AM
  #40
theUnderDog13
Originally Posted by Roxspin72
Not sure what you mean by chirp/flutter? I do know that if I accelerate aggressively and shift at say red line, I will hear a chirp... Only Chirp, No Flutter. According to my previous data logs, it seems I am maintaining boost, dumping via Diverter Valve (DV) and immediately building boost at completion of shift. Flutter would indicate a torn diaphragm in the stock DV. It can also be experienced w/an aftermarket DV, due to a seized mechanical DV piston from lack of grease/exposure to dirt & grime, etc... My Stock DV w/Alta spring has been working with no issues past 6-7mos. If I start hearing the flutter, end up in limp mode, or start dropping boost, I would immediately begin with an inspection of the stock DV diaphragm or aftermarket mechanical set-up.
Anytime I shifted, it made not only the whooshing noise I love but it came with a flutter noise and after I looked up what it could be, it could be damaging to the turbo even tho I felt a difference in power. Turns out it was most likely the Forge BOV adapter. Still have no clue why. But I'm now waiting for a new DV from Go fast Bits since the OEM was breaking its seal after taking it off a few times. I will probably still use the alta spring and will try it again with the forge adapter. It could of been because of it not sealing correctly.
Do you have a sound clip so I know for sure what the difference of the chirp and flutter noise? I thought it was one in the same and it's not good. When I shifted or even lifted my foot off the throttle , it would have that noise. Especially when it was more aggressive acceleration.
Old Apr 1, 2015 | 05:09 PM
  #41
Roxspin72's Avatar
Roxspin72
I don't have a clip... But if your stock DV is torn, that would be the flutter sound. Not the spring. The Forge adapter is probably amplifying the sound.
Im surprised that your MINI is not in Limp Mode. If you have a way to monitor boost, you should be able to see if you are reaching target boost, dumping and re-boosting upon shift. If there is flutter you should see low boost, or dropping quickly. If the spring is sticking, it would be holding boost longer than necessary, which could be damaging to the Turbo.
I heard good things about the GFB DV. Hope it all works out for you.
Old Apr 2, 2015 | 04:42 AM
  #42
theUnderDog13
I don't have a clip... But if your stock DV is torn, that would be the flutter sound. Not the spring. The Forge adapter is probably amplifying the sound. Im surprised that your MINI is not in Limp Mode. If you have a way to monitor boost, you should be able to see if you are reaching target boost, dumping and re-boosting upon shift. If there is flutter you should see low boost, or dropping quickly. If the spring is sticking, it would be holding boost longer than necessary, which could be damaging to the Turbo. I heard good things about the GFB DV. Hope it all works out for you.
Yeah I'm surprised too. Right now, I have no choice but to drive it the way it is ( not beating on it) till Monday.
I do not have a gauge for boost pressure. When I took off the Forge, it has all sound (with intake) but no increase in acceleration and it even sounds like a boost leak. So I am taking it easy.
I am hoping I can still have the Forge adapter cause I just got it and love the louder whoosh sound when I get on it. But it may be stuck in its box unless I sell it. Ugh
Thanks for the explanation !
Old Apr 27, 2015 | 08:58 PM
  #43
HZBJCW's Avatar
HZBJCW
I have a question. Does the Alta spring shorten the woosh sound? I notice in the video on the first page the woosh lasts so long it kind of sounds like a big leak. On the other hand I think that is the full forge valve (250.00), where I am only getting the adapter (basically a spacer,$42.00 shipped from US on Ebay).
My stock blow off valve is stuck closed. it makes no sound right now. If i get on it and lift i get a CEL and limp (justa cooper) mode.
I have a new stock style bov on order and a forge adapter on order. I am on the fence about the spring.
I haven't found any thread on the steps to do this mod. I wonder which way to point the holes? I just read about the adapter supposedly not working for the N14 for one poster but not too much corroboration. I guess I am going to find out for myself this weekend. (unless I get the spring). Should I get the spring?
Old Apr 28, 2015 | 02:36 AM
  #44
scubbysnacks's Avatar
scubbysnacks
[QUOTE=HZBJCW;4074771] On the other hand I think that is the full forge valve (250.00), where I am only getting the adapter (basically a spacer,$42.00 shipped from US on Ebay).
I haven't found any thread on the steps to do this mod. I wonder which way to point the holes? I just read about the adapter supposedly not working for the N14 for one poster but not too much corroboration. I guess I am going to find out for myself this weekend./QUOQUOTE
I got mine of Aliexpress for AUD$17(sorry to break you heart) probably where the eBay ones come from. Install is straight forward and only mounts one way where the holes on the dv line up with the adapter. Mine is an N14 but Euro model so no MAF sensor and zero problems.
Old Apr 28, 2015 | 07:05 AM
  #45
HZBJCW's Avatar
HZBJCW
Thanks scubbysnacks, I searched all night and could not find the answer to that question. I did find a lot of threads and this same discussion is going on regarding the CEL. The common thread seems to be the people who actually try it seem to not have many problems and the the people who are adamant it will throw a CEL seem to be describing an engine management system using a MAF sensor (where the N14 actually uses a MAP sensor) and it sounds for the most part like they have not tried it or just heard from others. I am jumping in with both feet, will report the results.
Old Apr 28, 2015 | 07:51 PM
  #46
nine5raptor
I never had any issues on my n14. sounded great!
Old Apr 29, 2015 | 02:14 AM
  #47
scubbysnacks
Not only that but its bloody loud. And if you have a auto and drive in sports mode as you decelerate you get the blow off + exhaust pop on gear change as the ECU maintains boost
Old Apr 29, 2015 | 08:39 PM
  #48
HZBJCW's Avatar
HZBJCW
Ok I took off my stock BOV. it pretty much fell apart while I was removing it, Cooked seals. I am still not seeing any holes. The bolt pattern is actually an equilateral triangle on the adapter right? (so there are 3 ways to mount the adapter) I wonder if the people who are getting CEL's just have it installed +/-120 degrees off? I know from the forge instructions (which by the way leave a lot to be desired, no pics of the product installed?) http://www.forgemotorsport.com/media/fmdvmcsrev.pdf the logo goes down. I don't think mine (ebay special) will have the logo, that said are the holes facing the front of the car or the rear?
update:
I found another picture of a forge adapter and the holes in relation to the logo would point to the front of the car. Anyone with a working set up care to chime in?
Old Apr 29, 2015 | 11:45 PM
  #49
scubbysnacks
Those holes may look like they have equal spacing but they don't. When you get your spacer put your DV on it to line up the holes. On mine the holes are facing up and to the front of the car.
Old May 1, 2015 | 10:17 AM
  #50
HZBJCW's Avatar
HZBJCW
Very interesting. My ebay special adapter has holes on 2 sides, none on the bottom, so the issue died for me when I took the part out of the box. Put me in the column of people with no CEL issue. Installation was a breeze. For some reason it is way easier to pit it on than take off.
Here are some pics: The Adapter showing both set of holes. My old blow off valve that disintegrated when removed and my homemade intake. From all the posts I expected this to be very loud. I can only hear it with the radio off and everything quiet int he car. It is not that loud, if the a/c is on I cant hear it. No louder than the intake.
I seemed to have lost some low end power. My old valve was stuck closed so just after I shift now feels really low on power. city gas mileage is also the lowest I have ever seen on this car (25, and no I was not testing the woosh noise). Highway is low also about 29 ( I used to get 31-32 highway, 30 city). I think I will get the Alta spring after all. Also it could be my home made intake, although before all of this that intake increased my gas mileage 1 mpg. I wonder if my new blow off valve is from an old S. Sure does feel like it.
Attached Thumbnails Forge Blow Off Adaptor For Cooper S Turbo-2015-04-30_19-39-00_283.jpg   Forge Blow Off Adaptor For Cooper S Turbo-2015-04-29_20-12-03_495.jpg   Forge Blow Off Adaptor For Cooper S Turbo-2015-04-30_19-58-38_59.jpg
