Drivetrain Awd r56?
Awd r56?
I wasn't able to locate any threads on it, so I'll just throw it out there. I am new to the Mini World (as of January), so I may not be as familiar with the engines and transmissions of the vehicles.
My understanding is that the engine from the R56 is similar (if not the same) as the Countryman. Could the AWD system from the Countryman be installed into a R56?
Yes it is the same engine. Yes you can do it if you have the knowledge and/or money to have it modified. I don't think anyone has every done it. But anything can be done as seen here.
That is a pretty complex system. It isn't four wheel drive, it's more variable than that. It shifts from four wheel drive to front wheel drive, on the highway, right? So at any given time, it may be anything from four wheel drive to front wheel drive, depending on conditions. Which means controlled by the ECU, right?
That would sure be a project!
You could probably buy both a fully loaded r56 and R60 for the type of money it would cost to have this done.
For example I just went to realoem.com and started adding up the parts cost of the R60 drivetrain. I easily got to $12,000 before I stopped, and I was not done.
COOPER Sx
One issues...where would you run the driveshaft...i guess if you cut the bottom of the r56 floor off... welded the floor and exhaust of the other car to it....
Colt45Magnus
Sep 14, 2015 03:12 AM
