Hey all,
I like to keep close tabs on my cars' engines with UOAs, and this new MINI is no exception. It was pretty much what I was expecting, loads of wear metals since it's a new engine. I'm definitely glad to have changed it early. I've always been a big fan of getting factory fills out early, but I decided to let this one go for a bit since MINI claims it's fine to go to 10k. We'll see how the next one looks at the 10k mark. I am running Motul X-Cess 8100 currently. I'll probably switch to the new fancy Mobil 1 0w40 after this run. I would have probably put it in for this change, if I had noticed that they reformulated it and that it was so robust. Blackstone listed it as supercharged, but this is clearly an R55 with an N18.
--Matt
--Matt
Interesting. I'm glad I got mine changed at about 5k miles...MINI will change your oil once a year or every 10k, evidently.
What is this "new" & fancy Mobil 1 0W40? I've been using it for years on my other car. Did they change something?
Quote:
Their new API SN spec oil has had some changes, and meets all of the latest manufacturer specs that you'd expect it to see. I believe they call it "New Life" elsewhere in the world, but it's just M1 0w40 European Formula with an SN label here.Originally Posted by JPR18
--Matt
