Drivetrain Catless No Tune?
Catless No Tune?
How well can the ECU cope with a catless down pipe? I am contemplating punching out the cat in mine while I have it off the car, but havent been able to find anything on how/if the stock tune is able to handle this change. Will I throw just a cel that needs deleted or will the ECU throw the car in a "limp mode"?
Any help would be appreciated.
Typically, the unmodified (stock) ECU sees too much cross-flow on the rear (post-cat) oxygen sensor, throwing a fault code to the extent of "catalyst system efficiency below threshold".
A Check Engine Light (CEL) will illuminate, but catalyst efficiency faults rarely affect performance...
To override the fault, you'll either have to "trick" the ECU that the catalyst is present and working, or have the ECU tuned to simply deny reading the oxygen sensor value.
- Erik
- Erik
- Erik
- Erik
What ways are there in tricking the ECU into thinking there is a CAT? I was just going to run with a code for a while and scan for more every weekend.
You will also notice the low end torque will drop when you go catless without a good ECU tune. Your high-end power will be a little better. I went for two years catless w/o proper ECU tuning. A good ECU tune is needed to smooth everything out. If I were you, I would wait out till you got a proper tune to go with the downpipe. It's just going to make more noise for the most part without that crucial piece of the puzzle.
Way Motor Works sells a electronic kit that prevents the downpipe codes from populating.
Colt45Magnus
Aug 27, 2024 05:03 AM
Sep 4, 2015 02:12 PM
Sep 2, 2015 12:57 PM
Aug 12, 2015 01:24 PM
