Drivetrain Where does this vacuum line go?
Old Aug 12, 2012 | 05:34 PM
Yyrd's Avatar
Yyrd
The pipe that goes between the Supercharger and the throttle-body has two vacuum lines. One I cannot find where is goes. The other runs into the firewall near the air-filter-box.
This mystery one is much shorter with a single curve in it. It is grey in color compared to other being black. Also its on the right hand side compared to other line
Im stuck, do help.
Old Aug 12, 2012 | 05:44 PM
ColinGreene's Avatar
ColinGreene
Goes to the secondary map sensor next to the head there is a small bracket that holds the map sensor into the tube there.
hope that helps.
Old Aug 12, 2012 | 05:45 PM
Yyrd's Avatar
Yyrd
thanks ill see if i can find it.
Old Aug 12, 2012 | 05:50 PM
ColinGreene
just make sure when you push both lines in they bottom on the rib on the tubes
they are very important
the black one is the vac source for the brake booster
and the white one as mentioned is for the map sensor.
why is the car apart anyway?
Old Aug 12, 2012 | 07:24 PM
Yyrd's Avatar
Yyrd
Put a new Flywheel/clutch in.
Been taking my time doing so. About 6 weeks now.
Old Aug 12, 2012 | 07:34 PM
ColinGreene
Ah, been there done that. best of luck to you.
its a ton of work. let me know if you need any other help.
Yyrd's Avatar
Yyrd
I found the Map sensor, seems i broke the air fitting underneath it.
Old Aug 12, 2012 | 07:38 PM
Yyrd's Avatar
Yyrd
I'm nearly done. I have only the front end clip to put back on. Maybe a wheel or two.
Ordered a CAI due Tuesday. add some more fun.
Wish one of you people lived down here in south east Florida.
scfiveo
Sep 27, 2019 02:27 PM
gar56
Nov 15, 2016 06:41 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
krohm
Sep 28, 2015 12:16 PM
EVMini
Sep 28, 2015 10:20 AM
