Drivetrain MINI-Madness COOPER S Intake Installation Instructions
Old Oct 17, 2002 | 10:33 PM
Mark's Avatar
Mark
North American Motoring :: Founder
This first of many installation write-ups by MINI-Madness and MINI COOPER Online relating to performance upgrades for your MINI. Please note that by proceeding with this or any install with information provided on MINI COOPER Online, you are doing so at your own risk. MINI-Madness and MINI COOPER Online are not, in any way, responsible for damage or warranty issues that may arise from modifications attempted using information on this web site. This article is Copyrighted © 2002 by MINI-Madness and MINI COOPER Online. Any use of this content without the express written permission of MINI-Madness and MINI COOPER Online is prohibited.
Required Tools
    Step 1:This is how the OEM airbox appears on the COOPER S (Figure 1). As indicated by the red circles in Figure 1, remove the 2 torx screws uing the T-20 Torx screwdriver.
    Figure 1
    Step 2: Remove and discard the factory hose clamp.
    Step 3: Remove bolt indicated by top-left red circle.
    Step 4: The battery terminal is attached to the side of the airbox. Lift the battery box off of the airbox mount. Be careful as there isn't much slack in the battery cable coming out of the bottom of the battery box. In effect you are just unclipping the battery box containing the terminal from the side of the airbox. This process does NOT disconnect the battery and therefore does NOT reset your radio presets or other features.
    Step 5: Remove the top of the stock airbox cover along with the paper filter inside. Figure 2 illustrates the box after removing the top cover and filter.
    Figure 2
    Step 6: Install the intake as shown in Figure 3.
    WARNING: The filter does not come pre-oiled and must be oiled before use. Failure to do so may result in poor filtration and/or potential engine damage.
    Figure 3
    Step 7: Use provided phillips screws to secure heatshield to bottom half of airbox.
    Step 8: Attach battery to mounting bracket on the left side of the heat shield. Again, be careful as there is not much slack in the battery cable.
    Step 9: Reinsert bolt displayed in top-left red circle.
    Step 10: Tighten hose clamp. Place hose clamp over rubber intake tube. Slide the tube onto the Madness Intake and then tighten the hose clamp.
    Step 11: You're done! (See Figure 4a) Go enjoy your newly found horsepower and torque. Be sure to view the before and after dyno results from our installation by clicking on the image below (Figure 4b).
    Figure 4a
    Figure 4b
    You can order the MINI-Madness Intake mentioned in this how-to by clicking >>HERE<<
    Further discussion on this intake can be found at -->HERE<--
    We'll say it again: Please note that by proceeding with this or any install with information provided on MINI COOPER Online, you are doing so at your own risk. MINI-Madness and MINI COOPER Online are not, in any way, responsible for damage or warranty issues that may arise from modifications attempted using information on this web site. This article is Copyrighted © 2002 by MINI-Madness and MINI COOPER Online. Any use of this content without the express written permission of MINI-Madness and MINI COOPER Online is prohibited.
    Mini'mon
    Aug 26, 2015 01:02 PM
    MiniJess
    Aug 10, 2015 09:51 PM
    iamcamkeenan
    Aug 10, 2015 03:31 PM
