Drivetrain Header/High Flow cat advice please.
sir i definitely have appreciation for anything that is well designed. but unless your rich your wasting your money on such an expensive manifold thats only going to be on your street car. and whats the point of a race header if your just going to weld a cat to it? defeats the whole purpose of those properly sized collectors if you ask me
A 1 hp gain catless in comparison to a high-flow cat.
Here's an interesting read for you: http://www.importtuner.com/features/...l/viewall.html
The stock cat works fine even on track if your car is running correctly. Tracked mine hard in aftermarket JCW like trim for 2 years without any problems & passed smog with flying colors. The majority of aftermarket cats are not as clean as stock and you may have MIL issues once they wear in and/or be dirtier at smog (if you pass at all). Even if you get 3-4hp from a modified motor by swapping the cat the gain is insignificant & won't be of use even on track. My aftermarket header needs a new cat after only 1.5 years and I doubt I'll be able to pass smog in its current condition.
i thought da ghost already made it clear that we werent aloud to use other cars as examples.
i didnt bother to read that article since it was clearly doing everything it can for the sake of trying to get the readers interested to try to prove that catless cars dont make more hp which I know isnt true.
third
....1hp? what does that prove? a car can easily vary 5hp in either direction between dyno pulls without any changes being made to the car. there are many different variables that will change the way the dyno reads like ambiant temp, humidity, heat soak, even elevation...ect
also high flow cats are notorious to melt and throw codes on our cars so i dont really consider them an option. and until someone gets a dyno sheet up here of a modded mini showing one heat soaked run of it with a cat and then another heat soaked run going catless as the only change on the same day, relativity the same time, and in the same shop, no one can say anything about it. all i can tell you guys is that i can definitely feel a difference with mine being out.
you can think whatever you want
Like I've said, unless it's a big gain, I don't think it's worth throwing more NOx and crap in the atmosphere for the sake of a couple hp. No matter the country or the regulation, I don't find it right for a street car, but it's my opinion. I'll run a cat on mine even if I track it almost every week!!
[quote=pmxgm;3571232]
the 20hp thing was not directed at you as you clearly said it was a track car
no one said you would be getting 20whp out of a catless mini. and i wont be proving it to anyone since i dont have a dyno and it wouldnt be "worth" it to cut and weld up my old cat and do dyno pulls comparing them just to show you guys what you should already know. also i was under the assumption that this was a conversation about both street and track cars.
of course its not going to be a big gain, hardly anything you do to our little cars is. even our beloved pulley swap barley generates much real hp unless you tune for it. anyone saying you can get 20hp out of a pulley is lying through their teeth. realistically were talking maybe 5whp out of a catless mini depending on your mods. if your car is really built up and is tuned for it of course there would be a bigger difference. but that goes for anything you change on our car. how much hp do you really think your getting from a stepped header? unless your car is built around and tuned for it, it wont be making a huge difference. and if your modding your car for the track or street im assuming your trying to get every bit of power you can get from our little motors and going cat less is just another step in the game
once i finish my classes my school is going to let us run our own cars on the dyno and i will see how much hp is really gained running all the mods i have on my car with the stock tune. im not expecting much from it. mods dont make the real difference until you tune for it. tune is everything
RMW 1.8L (bored w/sleeves, forged rods & custom forged crank), RMW Jesus head with larger valves, lightweight retainers, double springs, race cam, shorty header, 550cc injectors, JCW muffs, JCW intake, fluid damper, 17% pulley, custom software tune by me, OS Giken clutch & LSD, and plenty of other crap I'm forgetting... but it looks almost stock.
I did this "radical" upgrade after owning the car for several years & tracking it for a couple. The stock cat in these things is pretty damn good compared to most of the aftermarket. With my aftermarket header I had to modify the ECU tune to accommodate the lower cat efficiency and different o2 saturation limits, and change the downstream o2 voltage effect on LAM trim.
You can't rev out the 2.0's as much as the 1.8's
Test pipes are made for this exact reason. I already have planned the way I want my exhaust to be done and I'll have flanges on both sides of the cat (in case I get the infamous cat melting that some people are talking about) and one just before the muffler (in case I get pulled over and I have to change the muffler). While I'm at it, I will get a test pipe made just to get a dyno sheet comparison. I'm both curious AND annoyed by the lack of it as this is a subject that comes around every now and then here on NAM.
I went for a Dynomax VT, only thing is that center/center for this model is 3''. I'm doing a ''straight'' exhaust setup (battery box removed), I have no idea how it will sound and cops can be annoying over here if it's too loud.
By ''straight'', I mean that with the battery box removed, the exhaust will go from the header to the muffler in a straight line, no funky curves!
here Steve i think you will find this helpful.
http://lmgtfy.com/?q=light+weight+automotive+batterys
And as far as you feeling a difference on removing the cat, did you ever consider its psychological...
I see zero reason to remove the cat from the system in anyway. it smells and it puts unwanted pollution out.
Also I do remember an article about Supercharged Miatas making better torque with cats on then not.
I wont bother to find the article because you are convinced we are all wrong regardless of what we say because of your butt dyno.
That but dyno must be verry sensitive to be able to feel anything under a 5 HP gain. Most professionaly trained buts cant do that.
Maby its because he is running more than one header on his car, dont see too many MINIs with headers.
Odessy makes a pretty good small battery, I have had a PC680 in my car since 2008. I only had to replace it once because after a year of being parked while I was in Iraq the thing was DEAD! Didnt even have to pay for the new one though, their waranty is good aswell, so I put that money into a battery tender.
