Drivetrain Clutch Kit Time - What else?
Just got word that our '06 MCSC needs the clutch replaced. I've been searching and reading feverishly about this massive operation our little dear is about to go through. Of course, a true MINIthusiast ponders what parts could be replaced, while the car is dismantled basically from the firewall forward, improving the car and cutting down on labor cost at the same time.
My usual study-long research time is abbreviated a tad since I'm trying to get it all in before getting back to the service writer about it.
So far the pertinent parts up for replacement seem to be:
New MINI Cooper S Limited Slip Differential, LSD - ($1199)
Lightweight Flywheel
Performance clutch disk
Pressure plate
Release bearing
Performance pulley
Air Intake
Give me a boost...what else is nearby that might make sense to upgrade while she's so opened up for a clutch kit?
Pressure plate
Release bearing
Performance pulley
Air Intake
What I ended up telling them/deciding is:
1) The clutch is asymptomatic other than a low tone that happens on clutch engagement first thing on cooler mornings.
2) After reading through several blow-by-blow write-ups online, unless there's a very obvious problem it's not easy to diagnose the exact issue causing a behavior with the clutch, especially one like we're having. So the call to completely replace it, seems...ambitious.
So I'm going to get the car back, now that it's had an O2 sensor replaced, brake fluid changed, and a state inspection, and study all about clutch installs + upgrades while I enjoy the remaining life of this current clutch.
When you eventually get the clutch replaced, stick with OEM.
Don't believe any of the stories about aftermarket clutches being better - OEM is best...especially if you spend any time in traffic.
You'll probably have to go after-market if you make big power...else, stick to OEM.
andrewjg1994
Jan 29, 2021 07:45 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
