Drivetrain bushings and clutch time...
Old Feb 26, 2011 | 08:37 PM
jeffster06's Avatar
jeffster06
So I will be replacing my Lower control arm bushings and my sway bar bushings as well as my clutch pretty soon... I figure while I have my car all apart maybe I should mod/replace some preventative maintenance parts... my problem is I don't know what I should be considering... so far the only other part I can think of is to do powerflex engine/transmission mount inserts..
oh my car is an 06 MCS with 81k on the clock.
Old Feb 27, 2011 | 12:57 PM
jhiggs26's Avatar
jhiggs26
Inspect/replace thermostat. Inspect/service supercharger oil, especially water pump drive. Inspect/replace water pump and hoses.
Jeremy
Old Mar 1, 2011 | 11:09 AM
ntmid8r's Avatar
ntmid8r
My '06 just turned 53k and now the oil pan gasket is starting to leak.
If your going to drop your front end, maybe change the pan gasket.
Old Mar 3, 2011 | 05:29 PM
jeffster06's Avatar
jeffster06
The thermostat was replaced last year so I know that is good. I will definitely be checking those hoses... im kinda nervous about the SC scared to see it running low.. but im gonna see whats involved with checking that. as for the oil pan gasket I will say I don't believe I need to change mine my last oil change at 80k the underside of the car was virtually clean. I will be doing a short shifter a weekend or so before the big weekend so ill be giving the underside a good once over just to check for any possible parts I may discover I need.
patsum
26
May 29, 2021 06:29 PM
bahman
Nov 15, 2019 05:45 AM
Mrbrown
Suspension
11
Dec 31, 2015 09:31 AM
BadgeFTW
15
Sep 20, 2015 11:39 AM
Suspension Products
Sep 10, 2015 11:46 AM
