Drivetrain cracked valve cover
Old Nov 30, 2010 | 07:25 AM
freeskier's Avatar
freeskier
cracked valve cover
i cracked the valve cover on my r53 and need a new one asap. are there any aftermarket options? the stock unit is rater plain, i wondering if i could change it up a bit. thanks
Old Nov 30, 2010 | 05:17 PM
Vollgas's Avatar
Vollgas
I went through the same thing.
Could not find any aftermarket unit.
Picked up used one for $50.00.
Valve covers are plastic, might try Devcon or something like that.
Good luck.
Old Nov 30, 2010 | 07:12 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
No aftermarket option. I can get you a new one if you need, just give me a call.
Old Dec 7, 2010 | 09:12 PM
freeskier's Avatar
freeskier
i bought a used valve cover off member here and i have seen people post pics of them in red, any suggestions on what to use? thanks
Old Dec 13, 2010 | 01:47 PM
Vollgas's Avatar
Vollgas
Remove all fitting, valves, bolts etc.
Really clean surface with dereaser.
Take it to a good power coating place. they will do the best job over a can of spray paint.
Old Dec 13, 2010 | 02:50 PM
freeskier's Avatar
freeskier
ok, and are the fasteners studs or bolts? mine are really dangerously corroded, what is the best rout there? thanks
Old Jul 2, 2011 | 01:29 PM
lake3031's Avatar
lake3031
Does anyone have a valve cover for an R53? I need one ASAP! Thanks All!
Old Jul 2, 2011 | 02:11 PM
HRM's Avatar
HRM
Mine were bad too. I purchased a new set from the dealer (They were not terribly cheap) but in the North east, you can't find nice ones. In other places used are probably good as new.
THere are studs of different sizes since some cables use the long ones to clip to..
09R56
Nov 16, 2022 10:49 AM
schwac2
Sep 11, 2015 11:13 AM
PaulWalliDumali
Aug 21, 2015 04:46 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
