Drivetrain Warning: Cravenspeed Dipsticks
Old Aug 27, 2010 | 09:57 AM
sequence's Avatar
sequence
took my 09 S in to have the latest greatest tensioner installed, also to check out an annoying hood rattle. Dealer discovered that the Cravenspeed dipstick I put in right after I bought the car in Nov 2008 (because I could not read the OEM DS) was causing the hood rattle: sure enough, the top is too tall for the R56 S hood, and actually rubbed off some of the paint where the contact point is. Good job, Cravenspeed!
So I put the OEM DS back in and voila! no rattle, no contact. So now I have 2 dipsticks for one car: the oem DS for motoring and the Cravenspeed for checking. Sheesh, never again.
Old Aug 27, 2010 | 03:38 PM
MiniManiac74's Avatar
MiniManiac74
Just FYI, my stock dips stick rubs on my hood.
Old Aug 28, 2010 | 06:37 AM
sequence's Avatar
sequence
wow, talk about some precise German engineering here. so does the oem stick actually rub off the paint?
Old Aug 28, 2010 | 07:43 AM
MiniManiac74
It certainly did/does. At first I thought it was my M7 heatshield. I took off the heatshield and touched up the paint. At the end of the day it was rubbed again. I couldn't believe it!
Old Aug 28, 2010 | 08:35 AM
Dwight Walhood's Avatar
Dwight Walhood
I've got the Craven dipper on my '08 MCS and have no hood clearance issues. However, I did have a clearance problem with the m7 heat shield bolt. Solved it by putting a thinner washer under the bolt.
scfiveo
Sep 27, 2019 02:27 PM
OutMotoring
Mar 3, 2017 06:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
vetsvette
Oct 2, 2015 07:09 PM
WayMotorWorks
Sep 21, 2015 09:28 PM
