Drivetrain does heat from the reduction pullie produces kill my boost psi??
Old Jul 22, 2010 | 04:55 PM
dutch2081's Avatar
dutch2081
i have a mini cooper s 05 and it has a alta 17% pullei and it reads 12 psi to redline...now i know it should have more boost...so my question is ...does heat from the reduction pullie produces kill my boost psi??..i am installing a smow meth progressive kit just to cool the sc and ic, the nozzle is just b4 the throttle body, by reducing intake air temp with that show more boost on my guage??
thankyou
Old Jul 22, 2010 | 05:24 PM
mini_racer's Avatar
mini_racer
No and No.
My guess is that your belt is slipping. What belt are you running with that 17% pulley? The best belt for you to run is the Napa 060535.
Also, the common nozzle location for the Meth kit would be in the intercooler exit horn.
Old Jul 22, 2010 | 05:39 PM
dutch2081's Avatar
dutch2081
Originally Posted by mini_racer
No and No.
its a new 535 belt.. and as for the location of the nozzle, i was gong to but it there but mini madness did the same kit and they said they tried both locations and b4 the t/b was better for cooling. this way it cools the sc and the ic. i would be using a bigger nozzle..in the future when i tune it for meth i will add a second nozzle to the exit horn..
thanks for ur reply i just might get a new pulley..this pulley i have was on there when i bought the car...who knows whats really on it
Old Jul 22, 2010 | 06:47 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Dutch, replacing the pulley is most likely not the problem.
Check for boost leaks at the Intercooler couplers and the BPV. They are known to have issues and are a relatively easy DIY fix.
Old Jul 22, 2010 | 07:09 PM
dutch2081's Avatar
dutch2081
i did boots are in good shape and they r on right....and the bypass valve is good and did a vacume pressure test and it passed...no other leaks anywhere...i am stumped
Old Jul 22, 2010 | 07:11 PM
mini_racer's Avatar
mini_racer
Agreed, if you have the proper belt then you could be leaking boost somewhere.
Old Jul 22, 2010 | 07:28 PM
R53Warrior's Avatar
R53Warrior
Another thing is idk if you are supposed to inject meth before the supercharger. Probably isn't even effective since the air is heated post meth.
Old Jul 23, 2010 | 09:54 AM
-=gRaY rAvEn=-
Moderator
I would check the lower Supercharger Intake duct. There is a lime green gasket which is a huge issue for our cars. I had a bad leak there.
Where it attaches at the bottom there is a loop hole in the plastic which is normally round. The hole in this duct was somewhat oblong from moving so much. And where it attaches to the base of the SC horn (left arrow ) it was shiny from the plastic rubbing against it for some time.
Note - The new replacement horn was just replaced few weeks again...Again. When compared with the New new one, it was apparent that the original new one came from a bad mold and the green gasket did not fit inside it very tightly.
At one time, I was told M7 made their own aftermarket version of this intake duct made of metal or aluminum. Maybe Randy can pipe in if this is something still available. From what I have seen in handling and installing the plastic one, it does have it's issues.
Old Jul 23, 2010 | 10:19 AM
mini_racer's Avatar
mini_racer
While that certainly is a weak link in the intake, a failure here will not result in a low boost pressure reading as it is before the SC.
Old Jul 23, 2010 | 11:44 AM
ZippyNH's Avatar
ZippyNH
thankyou
A few questions
....how high above sea-level are you??
In some locations, that might not be too bad a number.....
And thermodynamically, the hotter the air as it goes into the IC, the more it will be cooled, so when the Meth is injected, it will cause some cooling....so they may recommend injecting it after the IC.
Remember, meth injection is also about adding octane, and preventing detonation!! To use it most effectively, a tune is used. The evaporation will cause cooling....but that brings up an interesting topic.....where to get the METH or METH/WATER mix...
Some folks use Blue windshield wash fluid....
This is made with TAP or well water...HARD WATER with MINERALS!!
THIS IS BAD FOR A MOTOR!! THE MINERALS WILL CRYSTALLIZE and FORM DEPOSITS that can cause WEAR!!
When this type of system is used in Aviation (I have, we used and 80% water, 20% meth mix) YOU MUST ALWAYS USE DE_MINERALIZED WATER......IE-DISTILLED WATER!! Anything else is a false sense of economy!! IT WILL CAUSE DAMAGE overtime!!
Another question...how many miles on the SC?
And did you have a PSI reading from before the pulley?
Old Jul 23, 2010 | 11:49 AM
dutch2081's Avatar
dutch2081
Originally Posted by ZippyNH
A few questions
132,000 km
no reading b4 the pulley change
i am in toronto Canada so not in the mountains
as for the location of the meth...mini madness recommended it to be b4 the throttle body..so i dunno i might put a second nozzle after the ic later
Old Jul 23, 2010 | 12:12 PM
ZippyNH's Avatar
ZippyNH
That would be kinda low, unless you have some head work (porting or a big valve head).....
Heat is an issue with the 17%....
it is great if the car is moving, so the IC is not heat soaked, but if in traffic in heat....not ideal. I'd look for leaks....Toronto is cool enough that IMO the 17% should be fine.
I'd install the meth kit as they recommend...maybe going through the IC ensures full evaporation, or ensures full mixing!! With a SC motor, it seems like an perfect system for when you want that extra kick...
A tune and two different maps/tunes would be ideal (with a flash tool), but heck...just ensureing the timing is not retarted on warmer days with full throttle....should make it NICE!!
Congrats! Good Luck o getting it sorted!!
Old Jul 23, 2010 | 01:35 PM
dutch2081's Avatar
dutch2081
well i just installed a new bypass...same psi....i dunno maybe there is head work done...but it only pulled 144hp 127 torque..low numbers...but maybe once i cool it down it will all work together and surprise me..
molala
Oct 2, 2015 01:53 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 3, 2015 01:45 PM
Sep 2, 2015 11:15 AM
Sep 1, 2015 04:39 PM
