Drivetrain Changing the pulley on an Auto MCS
Old May 15, 2010 | 06:30 AM
crammy's Avatar
crammy
Hi there,
I've read a lot of instructions for removing the pulley from a manual car however I think there are a few more brackets / attachments on the auto? Does anyone know what else needs to be removed on the auto to jack up the engine?
Thanks,
Crammy
Old May 15, 2010 | 03:16 PM
crammy's Avatar
crammy
anyone?
Old May 15, 2010 | 07:02 PM
ZippyNH's Avatar
ZippyNH
I have heard that there is a bit less room to work....so it is harder to do....not sure if anything is different....
Old May 15, 2010 | 08:37 PM
Suzanne's Chili Red S's Avatar
I was told when mine was done that the auto makes it necessary to lift the engine slightly to be able to access the pulley properly. Don't think there are any extra attachments that have to be removed.
Old May 15, 2010 | 11:39 PM
Cactusflier's Avatar
Cactusflier
I did my auto a few months ago. I thought the same thing but there are no extra brackets, you do not have to remove any cables from the tranny, nothing different from the instructions you find on line. You may need a second floor jack to help line up the engine as you lower it back down on it's mounts. I did.
Old May 16, 2010 | 05:13 AM
crammy's Avatar
crammy
cool thanks a lot everyone
Old May 17, 2010 | 08:22 AM
Helix13mini's Avatar
Helix13mini
The job is a lot easier if you remove the 4 16mm bolts that hold the trans mount bracket as well as the one that you normally pull fromt the trans mount. Pull the bracket out or you will scratch the driver's side shock tower paint. It takes a little more time, but it's worth it to give yourself room to work.
Old May 17, 2010 | 08:37 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Do like Helix said take the extra bolts out the trans mount. It will make it a little easier. The Automatic engine sits toward the pass side about a 1/4 inch further than the manual trans cars.
sprp85
Aug 22, 2015 06:16 AM
keck.j
Aug 18, 2015 08:18 PM
FLYM1N1
Aug 16, 2015 01:17 PM
azntaiji
Aug 13, 2015 03:24 PM
