Drivetrain getting ready to upgrade
Old Feb 11, 2010 | 04:00 AM
kshelt's Avatar
kshelt
Just wanted some good advice and things to know about upgrading the mini. I have a 2004 MCS. Im look at pulleys, intakes, front and rear links, ect. It looks like ALTA is the way I am going to go, but Ill take any advice I can get. Thanks!
Old Feb 11, 2010 | 11:55 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Feel free to give us a call, I can make some suggestions to help make your $$ go the furthest.
WAY
www.waymotorworks.com
317.201.8670
Old Feb 11, 2010 | 01:38 PM
quikmni's Avatar
quikmni
First you need to determine how you are going to use the car and what is your budget. Street driven, auto-x, or track days or maybe a combination of all three. You also need to think about the compromises you will accept such as more noise or a rougher ride. You will need to work out a plan so that the parts will work together, especially if your budget requires mods to be made over a period of time. For example, the size of a rear sway bar will be dependent on whether or not you add camber plates. The pulley size is a little dependent on how how plan to drive the car. There is also a limit to what engine mods you should do unless you get an ECU tune and larger fuel injectors. Also many aftermarket parts do not add much benefit and may not be worth adding so your money can be better spent on other items.
A place like WMW can help you develop a plan to spend your money wisely.
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
