Drivetrain guestamate my HP
Old Jan 18, 2010 | 08:35 AM
david in germany's Avatar
david in germany
guestamate my HP
So much for staying stock...
So now I am running the Alta CAI and 3" exhaust from the DP back. Butt dyno gives me a up but since there are no dyno's near where I live (that I know of) I am stuck with guessing my HP.
The exhaust is a Alta Catback mated to the stock DP with a custom 3" connection minus the second cat. This mod alone was a nice kick but with the intake, we will see.
Anyone running something similar and have dynoed?
Next mods will most likely be a Helix IC and possibly the Remote RMW tune.
Like I said, so much for staying stock...
Old Jan 18, 2010 | 08:38 AM
Helix13mini's Avatar
Helix13mini
If you like what you have now, wait till you get the IC and Tune, It'll be a different car entirely
Old Jan 18, 2010 | 08:39 AM
david in germany
I want to mess with my buddy that just bought a JCW!
Old Jan 18, 2010 | 08:43 AM
JamesHunt's Avatar
JamesHunt
you may have picked up 10 to 15 hp
Old Jan 18, 2010 | 10:38 AM
joshK's Avatar
joshK
dynolicious for the iphone gives more accurate results than a g-tech and it's cheap (if you have an iphone). It's not as accurate as a dyno but will be more accurate than basing your numbers off of someone else's car.
Old Jan 18, 2010 | 11:41 AM
ThumperMCS's Avatar
ThumperMCS
I can never get the damn thing to work right ...
Old Jan 18, 2010 | 12:14 PM
david in germany
Just installed! What are we loosing from drivetrain? I set mine at 15% is that accurate? I will test it out in the AM.
Old Jan 18, 2010 | 01:34 PM
Sabes's Avatar
Sabes
I would set it to 0% so you get the WHP, its a more useful and accurate number...
I keep my draintrain loss to 0% and my weight to 2850lbs
Old Jan 18, 2010 | 02:57 PM
Porthos's Avatar
Porthos
Ya I have an Alta intake with boost tubes and JCW catback exhaust. I am running around 153hp because the intake is making my car run lean. So when I put my FMIC on and have it tuned at the end of the month it will be all good.
Old Jan 18, 2010 | 03:24 PM
drewstermalloy's Avatar
drewstermalloy
I'd say between 185-190.
Old Jan 18, 2010 | 04:14 PM
JamesHunt's Avatar
JamesHunt
all r56 turbo cars are lean at low rpm(even with a tune) and very rich after 5000 rpm.
Old Jan 19, 2010 | 09:19 AM
david in germany
with the car weight at 2679 (Wikipedia) I pulled 166hp today with wheel spin in 1,2and a chirp in 3rd and 4th on a damp road. I don't think that this is too darn bad!
Acceleration was .53g's
I ca't wait till summer to swap out the winter tires and hit a dry road!
Old Jan 19, 2010 | 11:44 AM
Sabes's Avatar
Sabes
You only used 2679? You have to account for the driver and gas too. If you use a bit more weight, you should get a more accurate number which will be more
Old Jan 19, 2010 | 12:18 PM
david in germany
Ha ha, I didn't think about that! I even have a 70lb or so subwoofer in the back! Weight changed now!
Old Jan 19, 2010 | 02:00 PM
AkFarina's Avatar
AkFarina
I bet you have 160-65, your car it basically the same as mine
Old Jan 19, 2010 | 02:18 PM
Porthos's Avatar
Porthos
Well it was running lean enough that the guy wouldn't finish the dyno. So I don't consider that normal.
Old Jan 19, 2010 | 03:33 PM
JamesHunt's Avatar
JamesHunt
Did the Dyno Operater use a o2 sensor at the downpipe or put a sniffer in the tailpipe?
afr at 2000 rpm are around 15 to 1 and then go to 11 to 1 over 4500 rpm
Old Jan 19, 2010 | 04:04 PM
ThumperMCS's Avatar
ThumperMCS
A lot of them aren't used to seeing AFR's from a direct injection car...and the curves will make them go
Old Jan 19, 2010 | 04:08 PM
ThumperMCS's Avatar
ThumperMCS
Only after being tuned did my car ever see AFR's that rich.
Maybe its a JCW thing...but most of the S's I've seen run way lean. Back in the day when I first got tuned, it took Jan forever to try and fatten it up...it just didn't want to give fuel.
A lot of them on stock programming will do a weird lean spike around 5000-5500 rpm...where it will go to about 15:1...certainly makes your eyes go
Old Jan 19, 2010 | 04:09 PM
JamesHunt's Avatar
JamesHunt
Old Jan 19, 2010 | 05:08 PM
etalj's Avatar
etalj
as was mentioned above, D.I petrol engines run incredibly lean.
Old Jan 19, 2010 | 05:11 PM
JamesHunt's Avatar
JamesHunt
Looks like a Jcw ecu and map may be the key to running a BIG TURBO
Old Jan 19, 2010 | 08:45 PM
david in germany
I didn't say beat if you notice.
Old Jan 20, 2010 | 01:34 PM
Porthos's Avatar
Porthos
It was a sniffer I am pretty sure. I am still getting it tuned anyway because I am putting on a FMIC.
Old Jan 22, 2010 | 12:55 AM
Davidoyo's Avatar
Davidoyo
I just did the test tonight and I am running 155WHP. Thats with the weight set at 3015. Not too shabby!
