Drivetrain Scangauge xGauge - Now display BOOST without MAP
Old Jan 27, 2010 | 12:38 AM
  #26
Bilbo-Baggins's Avatar
Bilbo-Baggins
Back to the OP. Thanks, unclemeat. I'll be trying that later today.
Mine is mounted just in front of the "A" pillar on the dash, right up against the windscreen. Easily visible, out of the way, cable hides nicely in the gap between the dash and body.
Just wish that the R53 had the wideband AFR sensor.
Old Jan 27, 2010 | 12:15 PM
  #27
09MellowJCW's Avatar
09MellowJCW
Ok, I haven't tried to post pics in a forum for a couple of years. Lets see how this works...
Old Jan 27, 2010 | 12:20 PM
  #28
mikemc's Avatar
mikemc
me too.. i was on the fence about this piece
Old Jan 27, 2010 | 12:29 PM
  #29
mikemc's Avatar
mikemc
where did you say you got that mount? that looks real clean! mikey like it
Old Jan 27, 2010 | 12:41 PM
  #30
09MellowJCW
It's made by Craven Speed. They sell it as a kit (cradle, arm, and bracket). They're sold out of the cradle for three weeks though. I ended up getting the cradle from Moss, and the "R" bracket from Craven.
It's $99.00 as a kit from Craven http://http://www.cravenspeed.com/in...&productID=275. A little pricey, but it's a nice powder-coated aluminum piece. Not to mention the fact that it's a nice clean looking install IMO.
I thought about mounting it on the dash, as the ones I've seen like that look good too, but I also want to use it as a scan tool for more than one car. I think the Velcro would be a hassle if it's not left in one spot permanently.
Old Jan 27, 2010 | 12:44 PM
  #31
09MellowJCW
On a side note: I saw 14lbs of boost on my Scanguage this morning. Do these cars make that much stock or is my gauge off a tad?
Old Jan 27, 2010 | 01:00 PM
  #32
ThumperMCS's Avatar
ThumperMCS
Sounds about right for overboost.
Old Jan 27, 2010 | 03:35 PM
  #33
orangecrush's Avatar
orangecrush
Originally Posted by unclemeat
For awhile I've been running Scangauge Boost but only while MAP was displayed at the same time;
Well - Im getting the hang of this thing!!
Now display Boost pressure without having to display MAP at the same time:
TXD: 07DF010B
RXF: 0441850B0000
RXD: 2808
MTH: 00910064FFxx
Where FFxx will fit one of the following offsets:
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
Best way to guess your offset would be to first display MAP on the scangauage, and while the car is in neutral, press the start button but without the clutch pedal depressed. What this will do is initiate the engine electronics without starting the vehicle. Next, take whatever MAP number the scangauge displays and complete the MTH xGauge.
Save as BST
Start boostin without MAP concurrently displayed!
Hey UM,
THANKS!!! I did what you said and it works like a charm.
One question though... how did you figure that out? Was that in the instructions? I must have missed that if it was.
I'd appreciate it if you could enlighten me a bit so I can learn how to do it myself...
Thanks,
Mark
Old Jan 27, 2010 | 08:14 PM
  #34
09MellowJCW
And here's a night time pic
Old Jan 27, 2010 | 10:33 PM
  #35
joshknot's Avatar
joshknot
That looks really great. I've got my SG on the way...this mount may follow shortly.
Thanks for posting these pics up!
Old Jan 28, 2010 | 04:58 AM
  #36
unclemeat's Avatar
unclemeat
Well the VW guys aready coded this sequence; which worked for the most part... But we had to have BOOST displayed while displaying MAP at the same time. What I think the XGauge was doing was referencing the SC's MAP value directly instead of pulling the data from the car.
All I did was find an alternative TXD value that worked for our cars. If I can recall all I did was take what they found in a VW forum here http://forums.tdiclub.com/showthread...=202184&page=2 and changed a couple of digits which I thought would work for our cars:
VW version : TXD: 68 6A F1 01 0B
R56 Version : TXD: 07 DF 01 0B
Believe me, I was probably moreso excited about getting it functioning than anyone else. i think I ran around the house six times.
Old Jan 28, 2010 | 05:00 AM
  #37
unclemeat's Avatar
unclemeat
Guys;
Dont forget the other xGauge I programmed which shows the car's actual Air/Fuel ratio from the factory wide band O2 sensor:
CANSF Alt A/F Bank1 Sensor1 data -
TXD: 07DF0134
RXF: 04414534
RXD: 2808
MTH: 05B900800000
CHEERS!
https://www.northamericanmotoring.co...ge-xgauge.html
Old Jan 28, 2010 | 06:52 AM
  #38
orangecrush
Wow, THANKS!!! I'm still new to the SG so I'm still playing. At first glance, it seems pretty simple and straightforward but the more I play with it, the more of an important tool it can become.
As opposed to which other sensor does it read from?
Thanks again,
Mark
Old Jan 28, 2010 | 11:36 AM
  #39
unclemeat's Avatar
unclemeat
...The O2 sensor at the bottom of the downpipe...
Th xgauge reads the one right close to the turbocharger.
Old Feb 1, 2010 | 03:23 AM
  #40
eg0911's Avatar
eg0911
if someone could help me with oil pressure that would be amazing, its super important and it would be very nice to have. i would like to get egt's also but i dont think there is a sensor from the factory.
Old Feb 1, 2010 | 05:29 AM
  #41
orangecrush
X2
That's a great idea... it would be nice to have that option.
Mark
Old Feb 1, 2010 | 04:55 PM
  #42
Dwight Walhood's Avatar
Dwight Walhood
Guys;
TXD: 07DF0134
RXF: 04414534
RXD: 2808
MTH: 05B900800000
CHEERS!
Already used your info to get the BST working on Xgauge. Now I'm ready to try for the AFR, but got a question. Can you display more than one Xgauge at a time? Would kinda like to see BST and AFR at the same time, or am I getting greedy? BTW, thanks soooo much for the codes!
Old Feb 1, 2010 | 06:33 PM
  #43
ThumperMCS's Avatar
ThumperMCS
I have BST (mine is labeled PSI tho...) and AFR displayed at the same time with no problems....
Old Feb 1, 2010 | 06:47 PM
  #44
Dwight Walhood
YIPEE & Gracias!! Now to see how badly I can screw up the AFR install, LOL. BST only took about 9 tries. !?
Old Feb 1, 2010 | 08:13 PM
  #45
JIMINNI's Avatar
JIMINNI
So the R53 cannot read the AFR's?
So does anyone know if the R53 can read out the oil pressure? As you can tell I have a R53
Old Feb 1, 2010 | 10:02 PM
  #46
ThumperMCS's Avatar
ThumperMCS
Nope...old school technology in those cars
Still miss mine though....lol
Old Feb 2, 2010 | 05:27 AM
  #47
Barrettrw11's Avatar
Barrettrw11
Will the R53 read the Boost? If so I will probably jump on the band wagon and purchase the scan gauge.
Old Feb 2, 2010 | 10:15 AM
  #48
BlimeyCabrio's Avatar
BlimeyCabrio
yep. Here's the 1st gen thread:
https://www.northamericanmotoring.co...angaugeii.html
Old Feb 4, 2010 | 01:08 PM
  #49
Dwight Walhood
Xgauge AFR Measuring What?
Guys;
TXD: 07DF0134
RXF: 04414534
RXD: 2808
MTH: 05B900800000
CHEERS!
Used your codes to set the AFR for my R56 S and now have no clue what the
gauge is saying. It shows numbers from 0.04 to 0.09 for idle and under load. At one point, the display showed [U]two[U] AFR gauges! Did I screw it up again?
Old Feb 4, 2010 | 02:10 PM
  #50
ThumperMCS's Avatar
ThumperMCS
gauge is saying. It shows numbers from 0.04 to 0.09 for idle and under load. At one point, the display showed [u]two[u] AFR gauges! Did I screw it up again?
Yea....make sure you coded it right. If so, try the 'general' one on the link that unclemeat put in his post.
It should range from ~12.0 - 29.1...depeneding on if you're WOT or at idle and how rich/lean your tune is.
