Drivetrain Quick question regarding Megan header
Old May 16, 2009 | 07:09 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Hi motorers,
I have a Megan header installed on my car and want to buy a cat converter for it.
Which size should I buy? (tube diameter, length,...)
Any recommendation for a good one?
Will I be able to install a O2 sensor in it and get rid of the CEL?
Thanks a lot!
Old May 16, 2009 | 09:43 AM
checkmate2006's Avatar
checkmate2006
Originally Posted by DarkMiniCooperS
Hi motorers,
Which size should I buy? (tube diameter, length,...) 2ft of 2.25" outer dimension stainless tubing, two 2.25" inner dimension 2-bolt exhaust flanges
Any recommendation for a good one? Random Technology 300 or 400cell Catalytic Converter
Will I be able to install a O2 sensor in it and get rid of the CEL? Yes You will need to have a o2 bung welded in after the cat for the secondary o2 sensor. Also good measure if you have been running the car with the resonated test pipe to buy a new o2 sensor set which is one primary sensor and one secondary sensor
Thanks a lot!
The answers are in red. I hope I answered your questions clearly.
Old May 16, 2009 | 10:57 AM
DarkMiniCooperS
Thanks a lot CheckMate2006!
I really appreciate your help on this!
Old May 16, 2009 | 08:59 PM
checkmate2006
No problemo
Hippiehobbit267
Dec 3, 2019 04:22 PM
PhoenixR61
Aug 21, 2015 07:40 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
