Drivetrain M7 OCC DIY Baffle
Old Apr 10, 2009 | 01:28 AM
Qtip's Avatar
Qtip
M7 OCC DIY Baffle
Some have put tubes or some sort of media or both to increase the efficacy of there OCC. Well I wanted to go a little bit farther
A .030 thick piece of stainless steel, with a graduation of holes drilled in it, not pretty but I think it will work
a little silicone to seal the edge
inserted in to the OCC
what it looks like before I put the cover on. I have two pads on the out side and one on the in. Let me know what you think
Old Apr 10, 2009 | 05:45 AM
Bahamabart's Avatar
Bahamabart
great job, very nice.
conceptually similar yet different - I added a downpipe on the inbound side (3/4 of the way down) w/ holes drilled on the sides for the last 1/2 of the pipe from the end then stuffed similar medium.
The fact that you left the upper portion w/out holes should accomplish the same thing - great air travel path via medium.
Your set-up should be very effective.
Old Apr 10, 2009 | 01:14 PM
Qtip's Avatar
Qtip
thank you for the feed back
Old Apr 10, 2009 | 03:31 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Looks good. I should do something like this to my alta can. I just stuffed it with steel wool and called it good.
Filmy
15
Jun 6, 2023 06:27 AM
M7Speed
Oct 1, 2015 07:05 AM
micromini234
Sep 30, 2015 07:36 PM
donniedarko
Sep 29, 2015 01:16 PM
whowantstorace
Sep 27, 2015 06:16 PM
