Drivetrain K20 in a MINI
Old Nov 10, 2008 | 01:20 PM
Grinder's Avatar
Grinder
K20 in a MINI
Hey guys,
What would it take to put a K20 of some sort into the MINI? I've worked a lot on cars, but have never done anything like an engine swap before.
How does the size of the stock 1.6 compare to a K20...would there be reasonable space (I mean Qvick put the M3 engine in their MINI, but that musta been tight)?
How much work would need to go into manufacturing engine mounts?
Has anyone done something like this before? My search didnt turn up many results for NEW minis with vtecs, mostly just old ones.
Old Nov 10, 2008 | 01:33 PM
not-so-rednwhitecooper
Honda engines are too big, I already did the measurements.
I wanted to put a K in a MINI a while ago.
The M3 MINI is a full hand fabricated race car. The only resemblance to a MINI is in the body, and it stops there, nothing else is the same.
Old Nov 10, 2008 | 01:40 PM
MINIdave's Avatar
MINIdave
Edit: oops, thought you meant a classic - sorry........
Old Nov 10, 2008 | 01:54 PM
//MZero's Avatar
//MZero
Money can move mountains
Old Nov 10, 2008 | 02:13 PM
MINI_chili's Avatar
MINI_chili
with enough money and time you can make the MINI mid-engined with a v10... if one felt so inclined
Old Nov 10, 2008 | 02:15 PM
checkmate2006's Avatar
checkmate2006
it has been done in the UK and for the amount of money and work it would be cheaper to go with a RMW 2.0L Stroker which would be PLUG AND PLAY practically
Old Nov 10, 2008 | 04:15 PM
mitemini's Avatar
mitemini
Its been done about 4 years ago....BTW for sale
http://www.trickmedia.co.uk/zblog/carsale/index.php
I have one in my classic....see below
Old Nov 10, 2008 | 05:07 PM
user 7082082's Avatar
user 7082082
Why a K20 ? There are so many things you can do now to get up to 260+ hp with a fair amount of money. I think putting a K20 and wasting all the money is not a good idea. A good K20 motor with low miles is going to cost you around 4k. With 4k you can get to 270hp easily.
With a little less then 4k, I am at 250whp and 192tq. With about 1k more, I will be at 270whp and around 205tq.
-Arthur
Old Nov 10, 2008 | 05:19 PM
Longboard Mini's Avatar
Longboard Mini
Who needs a K20 .
Longboard
Old Nov 10, 2008 | 05:45 PM
ED955S's Avatar
ED955S
If the K20 is heavier, the weight distribution will be even >f:r and decrease the dynamics of the car. You need to rev the K20 to get the TQ & HP.
Old Nov 10, 2008 | 08:27 PM
checkmate2006
Originally Posted by checkmate2006
it has been done in the UK and for the amount of money and work it would be cheaper to go with a RMW 2.0L Stroker which would be PLUG AND PLAY practically also to top it off have more hp and torque then the K20
Is my post invisible
Old Nov 10, 2008 | 10:16 PM
//MZero's Avatar
//MZero
What does this guy keep saying?
Old Nov 10, 2008 | 10:23 PM
LüDICRöüS's Avatar
LüDICRöüS
Originally Posted by COOUUPER S
Why a K20 ?
come on, he wants that VTEC!!!
Old Nov 10, 2008 | 11:43 PM
MrCooperS's Avatar
MrCooperS
Moderator
M3 engine in a MINI? Wow. That must be a load of work considering one is a FF and the other is a FR.
Old Nov 10, 2008 | 11:49 PM
call it spade's Avatar
call it spade
well first you need a K20.
Old Nov 11, 2008 | 12:26 AM
justintime's Avatar
justintime
lol, thats not too difficult. and as checkmate said its been done. from what I have researched on this.. and I have looked into it pretty deep you will need about a 13k budget. is it worth it? hell ya it is! k20 is an amazing powerplant.
you will need a k20a drive by wire, standalone, custom axles, custom motor mounts, and then you will probably be nickle and dimed to death. luckily the k20 bolts in the same as the mini motor. keep in mind putting a motor in can be tricky as you can easily mess up the weight distribution of the car. I would not do something like this by yourself if you dont know 100 percent what you doing. but it will fit, so will the f20 from my measurements
btw.. theres a guy here in san antonio that has a b18 in his mini.
Old Nov 11, 2008 | 01:03 AM
silversmoke06's Avatar
silversmoke06
I have one in my Friends Lotus.
Its kinda pointless for a mini. Ill Rape him out of a light till the bastard gose Nuclear and takes off I mean the phrase Over 9000 has never been more Right.
Seriously im not seeing the point is dropping that into a mini for a daily driver.
A Track car? Sure why not. Its just not cheap.
I hand built his motor its 307 hp at 9700 but it cost him close to 9k FOR THE MOTOR ALONE.
Old Nov 11, 2008 | 01:18 AM
justintime's Avatar
justintime
lol, this wouldnt make a good daily... for me its perfect as I love a free flowing high reving motor. I also want a motor that is reliable, almost stock, and around 200hp. thats all I want in a motor. the k fits my bill perfectly. I also have a cooper so the difference is much different. If I had an s I would probably look at some of jans stuff as the k20 would be more for fun/awesome than being realistic..
Old Nov 11, 2008 | 02:39 AM
MINIdriver85's Avatar
MINIdriver85
Well, for 10k you could get a 2.0 stroker from Jan...no need to make custom mounts or axles, you'll just have to swap the tranny to the Getrag 6speed but you'd have to swap the tranny anyway with the K20, so...
Old Nov 11, 2008 | 10:39 AM
justintime's Avatar
justintime
I have the getrag 5spd, which I still am curious of its capabilities. But I doubt the stroker would put me where I want in all aspects. And by custom axles I dont mean making them. you can still use part of the minis, but you will need the axles from the k20 as well. The other aspect of the swap is motor placement, I want to set it back alittle bit and lower. this is also why my project will require a lot more mula, and I wont be able to do it for a long long time :D dreams
Old Nov 11, 2008 | 10:45 AM
checkmate2006
WAT!
Old Nov 11, 2008 | 10:51 AM
justintime's Avatar
justintime
mm stock
HP 220 @ 8000RPM
Torque 152 lb/ft @ 7000 RPM
Redline 8400 RPM
Bore 86mm
Stroke 86mm
Comp Ratio 11.5:1
Displacement 1998cc
Specific output 110HP/
comes stock with lsd
Old Nov 11, 2008 | 11:54 AM
amg6975's Avatar
amg6975
I always wanted to destroke a k20, build the head and see how high it could make power. I'd imagine with a little work you could build a 1.6-1.8L that could turn motorcycle-like revs. Then just tack on a small supercharger to make some torque and enjoy.
Old Nov 11, 2008 | 12:54 PM
MiniStupidfun's Avatar
MiniStupidfun
a k20 would be alot nicer in a dc2
Old Nov 11, 2008 | 04:45 PM
MrCooperS's Avatar
MrCooperS
Moderator
How about a Hayabusa Engine in a MINI?
