Drivetrain How hard is it to make a new cap for the coolant tank?
Old Nov 6, 2008 | 09:05 AM
Mike S's Avatar
Mike S
Hi guys,
My coolant tank was leaking at the seam so I had a new one made from aluminum. I have the tank now but the problem is the fabricator put on the wrong nozzle. It's too small to use the OEM cap.
How hard would it be to make my own one? From what I understand if it does not have a "release" mechanism to let pressure out it will start bursting my lines. Or can I just use any cap without this feature?
Old Nov 6, 2008 | 12:05 PM
Mike S's Avatar
Mike S
Anybody? This is very urgent as I need to have a solution within the next couple hours. Otherwise my car can't run :( Much appreciated. Thanks!
Old Nov 6, 2008 | 12:52 PM
Mike S's Avatar
Mike S
Additional info: The nozzle is narrow by a couple mm more than the standard size. Anybody know any other car which uses a slightly smaller size cap which I could use directly onto the new tank?
Old Nov 6, 2008 | 01:07 PM
herbie hind's Avatar
herbie hind
use a moroso 27- 30 lb. cap . this is what we run with the canton tanks. look them up . i've run this cap for a long time now with no problems .
Old Nov 7, 2008 | 10:11 PM
Mike S's Avatar
Mike S
Thanks for the reply. I went to every dealer in my area. I eventually sent it into a shop nearby and had the neck cut off and had a new neck welded on. It works perfectly now! I'll post some pics later.
Kimolaoha
Jul 5, 2023 01:04 PM
W0TM8
Dec 19, 2019 07:50 AM
blackie
Jan 18, 2017 09:56 PM
SosoMINI
Nov 22, 2015 03:17 PM
kwijmbo
Aug 5, 2015 09:00 PM
