Drivetrain Springs or Pulley?
Springs or Pulley?
hey there guys..i decided to post this on this section of the forums cause it seems to get more views
but im on the fence on which to do..
my birthday passed..( a month ago.. ) and my gf is buying me a part for my car
and i was trying to decide..on whether or not to buy TSW springs..or a 15% alta v2 pulley (currently on sale
i would assume that i'd have to spend about the same amount of money..more or less
i dont track my car but would like that added power for highways and a bit more power for lower rpm..but then again..lowering my car wouldnt be too bad either..would make my car look much better and handle a bit better too..(and a bit of a more comfortable ride?)
wat i do have done to my car so far is pretty much just a ddm intake..
and painted r83's semi black..
i will be tho..painting my arches in the near future
so all opinions and suggestions would be GREATLY appreciated..
(and im gonna assume right now that most of you guys will say pulley?
I would go for the pulley first
And she seems like a cool girl, knows what to buy, parts for your car
My wife now gets me gift certificates at the local Custom Mini Shop
for Birthdays and Christmas.
PULLEY. Thats what I did and couldnt be happier. I am now calling my GF, I want a new exhaust or some wheels!
ALRIGHT..i decided to buy BOTH!!
bought ddm pulley along with tsw springs..
so i guess i will be putting on both..
thanks for those who gave an input on which to get..i just STILL couldnt really decide..so ended up gettin both..whether or not i install em both at the same time or seperately
i will update with pics along with all my other mods i havent showed anyone else yet..
hopefully you guys will like..
Oh BTW, not sure what year your car is, but I think 05 and later were able to have small adj. with the OEM rear control arms Banned
The TSW springs will lower the rear about 7/8 of an inch. If the MINI was built after Jan 2005 then it should have the small camber adjustments if not or not enough you can get the TSW Rear Adjustable Control Arms to match the springs. Since he got both out of the GF this time, maybe she will get him the Arms for X-Mas
lol maybe..but mine is a 2006
but how do i go about changing the camber adjustments?
and how much do i change it by? im still a bit iffy on the suspension subject of things..
i just know the gist..maybe someone could enlighten me on wat do to?
thanks in advanced guys
Once you get the springs in give it a tank of gas to see where the rear camber sets up. If it's way off you will need to get it to an alignment shop for a 4 wheel alignment. If you are over 200 pounds I would sit in the MINI for the alignment so the rear runs flatter with with you driving, yes 200 pounds can change things back there. The computers on the newer racks tell the mech what, where and how much. Ask around for a good shop if you don't have one lined up, plan on spending about $100.00.
hmm well thanks for the info..i was expecting to get an alignment especially after the springs go in..but how do i check rear camber? and uh..sorry for my ignorance..but wat is camber exactly? i never got a good idea of wat it exactly is
when you lower the mini the wheels look like this / \ that's negative camber. you may need lower control arms to correct too much negative camber. if so, i have the "new" helix version and have had no problems.
The OEM settings are a little neg, so you should be able to pull out too much neg camber that you find in the rear with the OEM arms.
i dont think the oem control arms are gonna do the job here. the tsw drop is less and you could be fine.
