Drivetrain hey jan ;
Old Aug 11, 2008 | 03:29 PM
  #26
Nitrominis's Avatar
Nitrominis
Originally Posted by PGT
the fan failure leads to the pump failure. I'd be shocked to find a pump failure and no fan failure. I haven't gotten under there to look how it's set up but it would seen best to somehow relocate things in such a way as to make debris a non-issue. The only PS failures we saw on Subaru's was due to jacktards cutting the wheel to full lock and doing 'scoobynuts' (awd 360 spins) which puts enormous load on teh motor. The MINI steering is hydraulic and not electrical correct?
The MMMC had several fan failures last year. Chad @ Detroit Tuned replaced most of them. I only recall of reading a couple pumps?
I would like to know what the temperature get around that area? Also how well the PS fluid circulates?
Old Aug 11, 2008 | 04:03 PM
  #27
AliceCooperWA's Avatar
AliceCooperWA
That would seem pretty easy to measure, the tubing from the pump is metal, so couldn't we just do a laser temp reading on the tubes?
Honestly, I think it is a good idea. If the oil could be cooled without the use of the fan...say with properly positioned heat sinks etc...without raising the temps, then go for it...it definitely needs testing! What I would be concerned about without having a fan is the lovely 100 deg days here stuck in traffic. How would it the oil cool down with no air moving?
Old Aug 11, 2008 | 04:05 PM
  #28
herbie hind's Avatar
herbie hind
Originally Posted by Nitrominis
Ya I Have followed a couple forums with the fan issue. I racked the mini and took a closer look. There just is very little air that can get around the pump. I am not sold that Moss’s solution for the fan will actually work as well as I they claim? And the other devices to protect the fan will just hinder airflow. I think that eliminating the fan altogether running a small oil cooler and possibly going to a relocated reservoir. I need to think about it a little more. I also called a rep I know at Royal Purple to ask about their PS Fluid see if it will completely replace the Mini's CHF 11S fluid. This by itself may save a few pumps?
The master cylinder I am not sure I can do because how it is mounted.Now the slave may be doable?
My engine oil cooler was criticized as overkill by a few around here !
not by me . i got one too . the guy that serviced my car under warranty said the total fluid was way not enough and he couldn't believe it from a bmw . he thought lines to a remote cooler was a must .
Old Aug 11, 2008 | 04:10 PM
  #29
herbie hind
a small cooler with a muffin fan attached . maybe a battery delete with stainless lines to - from for added cooling . put the cooler in the old battery box .?
Old Aug 11, 2008 | 07:29 PM
  #30
Nitrominis's Avatar
Nitrominis
Good idea I have a raytech hand held. I will do some readings
This is my engine oil cooler. What do you think about a smaller version may work for the power steering fluid? I have this manually and thermostatically controlled.
Old Aug 11, 2008 | 07:50 PM
  #31
AliceCooperWA
Where would you put it? I think that it would have to be repositioned away from where it currently is, otherwise you risk ingesting bags etc causing the fan to burn out. It is not that likely, but on a large scale, it WILL happen to someone. I like the idea of the battery box, but then you have to lose the spare. I think the fail rate is mostly because of the quality of the fan, but I think it is also the position under the car and the fact that it will hold on to certain types of debris at lower speeds because of the suction it produces.
Old Aug 12, 2008 | 01:49 PM
  #32
herbie hind
i'm wondering if just lines to the back and then return to pump would be enough. the added volume's gotta help yes?
plus would n't it get some air going aft and back up ?
Old Aug 12, 2008 | 02:23 PM
  #33
AliceCooperWA
I think the best idea would be a fan above the cooler blowing down (towards the ground) with a duct above the fan pulling the air from somewhere. That way you get the cooling needed from a fan with out having to suck from under the car. Pushing the air down could be more reliable for that problem. The problem then is where to position the duct so that it will not suck up passing debris.
I don't know if it is even feasible with the given space though.
Old Aug 12, 2008 | 02:43 PM
  #34
kapps's Avatar
kapps
The positioning of the fans depend on how the air flows through (and under) the engine bay. If the MINI was designed to have air flow up and you put a fan in pushing down, you're not going to do much good.
Old Aug 12, 2008 | 03:00 PM
  #35
Nitrominis's Avatar
Nitrominis
The Minis very little air comes in the front over the top of the engine and out around the exhaust manifold. And most of the small amount is from the radiator are not the scoop.
Played around with the Raytech on a friends bone stock 04 MCS. The reservoir gets cooked at about 250 or more. A lot of the heat radiates off the exhaust manifold. So this is not an ideal place for the reservoir. The lines stay constant at about 170 but that is because of the oem aluminum wrap. So I do not know what the actual line temp was. The powersteering box only got around 140. This is not totally conclusive but it shows that the oil is getting heated in the reservoir?
Old Aug 12, 2008 | 05:21 PM
  #36
kalbone's Avatar
kalbone
PS is overrated..lol
Old Aug 12, 2008 | 05:39 PM
  #37
herbie hind
agreed . too bad we couldn't find a rack that fit with 16 or more to 1 ratio . i've got h.a.i. so i have some room in bay on drivers' side . if i can get some time i can see if there's room for a small cooler sharing the incoming air from where the cai used to get it's air. with the bottom of the stock box removed the air flow is good .
Old Aug 12, 2008 | 05:45 PM
  #38
Nitrominis's Avatar
Nitrominis
Interesting idea. What kind of cooler are you looking at?
Old Aug 12, 2008 | 06:07 PM
  #39
Nitrominis's Avatar
Nitrominis
This is what I had in mind as a cooler
High PSI silicone line FI SS clamps and Hi tech cooler.
And I painted it red for the extra 5 hp
I am looking into different reservoirs now? I think this and the res will solve the heat issue?
Old Aug 13, 2008 | 04:04 PM
  #40
herbie hind
wow nice ; i was thinking of the smallest cooler from summit i could find then try to fab around it's dimentions . what kind of pressures are we lookin' at ?
Old Aug 13, 2008 | 04:05 PM
  #41
herbie hind
don't forget ; with the addition of longer lines you are now nullifying the small volume of the current resevoir . so, you may not need another res,
Old Aug 13, 2008 | 04:15 PM
  #42
herbie hind
what size an fittings will fit the pump?
Old Aug 13, 2008 | 05:45 PM
  #43
Nitrominis's Avatar
Nitrominis
You are thinking! I believe that with kind of set up a reservoir may not be needed at all. I am looking into how much fluid expansion there would be in the power steering lines. It may be that all that is need is a way to introduce the fluid into the system with a vented cap. In this case the cost and conversion would be low and simple to do.
Old Aug 14, 2008 | 12:31 PM
  #44
herbie hind
man you're way ahead of me ; are you looking to do a fan still? have it t-stat controlled? or just put the cooler in the breeze? i like the fan bit cause of the traffic scenario posted earlier. who's cooler is that?
Old Aug 14, 2008 | 01:35 PM
  #45
kapps's Avatar
kapps
Explain why you don't think there will be a need for a reservoir? Assuming the PS fluid responds like most other fluids and expands when heated, it's going to need some place to go. With more fluid in the system in the additional cooler and lines, you may need a LARGER reservoir. If the cooler works efficiently and keeps temps down, the stock one may work fine because the fluid won't expand as much.
Also, you have to figure into your setup the ideal operating temperatures. Looking on Pentosin's site, the viscosity ranges from 1100mm^2/s at -40C to 18.7mm^2/s at 40C to 6mm^2/s at 100C. What does the MINI's pump want? Will having too cool a fluid hurt performance like with engine oil?
Old Aug 14, 2008 | 06:38 PM
  #46
herbie hind
me? i'm thinkin' a res. is needed . just not an additional one . if we can keep temps consistant then maybe the stocker will be fine . summit does have a bunch of reasonably priced coolers . just don't know what kind of p.s.i. and fittings we.re lookin' at .
Old Aug 14, 2008 | 06:43 PM
  #47
herbie hind
doubt if we'll find a sorce for what the pump wants as bmw certainly doesn't have a clue . but they will sell you another . and damned if i know why so many racers put oil coolers on their cars ? thermostatically controlled of course.
Old Aug 14, 2008 | 09:05 PM
  #48
Nitrominis's Avatar
Nitrominis
This is good information.
Because of the additional capacity of fluid actually a smaller reservoir would be more in line with the project. The goal is to lower the temperatures and the by product would include less oil expansion to the point that only a small expansion tank or small reservoir for adding fluid be needed. The type of fluid CH11S used would only be effected in sub cold temperatures. So cooler is better with anything except driving to the south pole. LOL
The addition of a fan can be done but that starts to limit availible mounting of the cooler and fan combination.
Old Aug 14, 2008 | 09:10 PM
  #49
JIMINNI's Avatar
JIMINNI
Dude, do you actually drive your car Thats just beautiful
Old Aug 15, 2008 | 09:18 AM
  #50
MINIFVR's Avatar
MINIFVR
^^^ +1. Very pretty!
