Drivetrain polyurethane engine mounts
Old Jul 29, 2008 | 10:15 AM
CaMiniMe's Avatar
CaMiniMe
i was curious who has them on their r56 and if they like them? once installed did it do anything to help the "thud" between hard shifts?
thank you
Old Jul 29, 2008 | 01:00 PM
Kirkland's Avatar
Kirkland
The mounts noticeably helped. Probably would not want to use them in sub-zero winter areas because as they stiffen, they would allow too much vibration. This vibration, in cold weather, is only noticeable for a minute or two. Shifting engages more positively and engine does not move around much anymore at full throttle.
Simple install: remove one bolt, loosen a second bolt, pop in two inserts, and retighten.
Old Jul 29, 2008 | 03:34 PM
CaMiniMe's Avatar
CaMiniMe
thanks for the response. i think ill have to get them. im not too cocnerned with vibration. but if they help keepm the motor in place a little better im all for that. thanks again
Old Jul 29, 2008 | 08:43 PM
scott48's Avatar
scott48
where'd you get yours from?
Old Jul 29, 2008 | 09:27 PM
Kirkland's Avatar
Kirkland
http://www.mini-madness.com/index.as...ROD&ProdID=293
Old Jul 30, 2008 | 03:28 AM
ENGINE 58's Avatar
ENGINE 58
i have the madness ones and i like them.
woodstudio
Mar 15, 2020 08:28 AM
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
sleek55044
Aug 21, 2015 10:52 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
