Drivetrain M7 Super-AGS install
Old May 23, 2008 | 06:05 PM
morbius's Avatar
morbius
Dr. Morbius
edited ....
Old May 23, 2008 | 06:20 PM
ENGINE 58's Avatar
ENGINE 58
very nice let us know more about the performance when you floor it some more.
Old May 23, 2008 | 06:26 PM
PGT's Avatar
PGT
Originally Posted by morbius
Very happy with the results, will not bother to mention the gains I am getting by monitoring the output of the computers.
gains? mpg? power? IAT?
Old May 23, 2008 | 07:09 PM
morbius's Avatar
morbius
Dr. Morbius
edited ....
Old May 24, 2008 | 07:19 AM
n1tr0's Avatar
n1tr0
did you take any pictures of it before you installed it ? & what's the inside look like ?
I'd also like to see some pictures of the hoodscoop from a ways back, I'm assuming that's the Vortex ?
It looks good
Old May 24, 2008 | 08:17 AM
Astro S's Avatar
Astro S
Looks good Morbius
Definitely a huge filter area! Nice fit and finish as well. I'm curious as to why you decided to go with this as opposed to others out there.
What do you plan to do with the scoop re. color?
Cheers
Old May 24, 2008 | 08:54 AM
tazio's Avatar
tazio
Boost figures are higher. In replicating a couple little test, before the ags, I was doing 4.6 PSI boost. With the ags installed, now on those same little tests, I am doing almost 7 PSI boost.
Really!?
Old May 24, 2008 | 09:35 AM
morbius's Avatar
morbius
Dr. Morbius
edited ....
Old May 24, 2008 | 09:45 AM
morbius's Avatar
morbius
Dr. Morbius
edited ....
white rocket's Avatar
white rocket
This is my top choice so far for intakes. Thanx for the review . Nice to hear that the noise doesn't increase very much.
Old May 24, 2008 | 09:48 AM
morbius's Avatar
morbius
Dr. Morbius
Originally Posted by tazio
Really!?
Not claiming facts. They where very short test run and yes I pulling much more air without restrictions and increase in boost would be a given. The gauges are showing that. More testing is needed, but I am happy with what I seeing so far !
Wait when I pull that turbo and do some of my special work to it ! The new CAI will be worth the money and highly needed.
Old May 24, 2008 | 09:55 AM
Astro S's Avatar
Astro S
Thanks for your insight and experience.
Like most, I'm planning on an aftermarket intake and exhaust so I'm always curious as to why people go with what they go with. My only other experience was with a '94 GTI.
Old May 24, 2008 | 11:05 AM
morbius's Avatar
morbius
Dr. Morbius
edited ....
Old May 24, 2008 | 02:09 PM
morbius's Avatar
morbius
Dr. Morbius
edited ....
Old May 24, 2008 | 02:12 PM
MotorMouth's Avatar
MotorMouth
I think he said REALLY? because you should be pushing much more boost than that completely stock.
Old May 24, 2008 | 02:31 PM
morbius's Avatar
morbius
Dr. Morbius
edited ....
Old May 24, 2008 | 02:53 PM
MotorMouth's Avatar
MotorMouth
Sorry mis-understood. Yes, I pushing much more boost compared to stock and much easier. I have not even tried pushing it yet, raining here so been taking it real easy.
7 lbs of boost is only half of what you should be pushing stock if you have an R56.
Old May 24, 2008 | 03:14 PM
Guest's Avatar
Guest
Based on my testing we saw about 11.7 PSI of boost with sport mode and DSC on. With DSC off interestingly enough we saw 13.4 PSI.
Old May 24, 2008 | 03:40 PM
morbius's Avatar
morbius
Dr. Morbius
edited ....
Old May 24, 2008 | 03:41 PM
morbius's Avatar
morbius
Dr. Morbius
Great, that is nice. I was not testing that way. My test around the area and taking the kids to school and pickup where I have prior numbers ......
Old May 24, 2008 | 03:53 PM
PGT's Avatar
PGT
How does one reliably test boost at part throttle? The extra boost could easily have been to a shallower angle of the long skinny pedal...nothing to do with potential gains from a mod
Old May 24, 2008 | 03:58 PM
Revolution Mini Works's Avatar
honestly.... I could care less if it made 40psi of boost.... in the end... what actual HP did it make to the car?
I'm still trying to figure out how tabs welded inside the box at the wrong angles to divert airflow would do anything to help but hey.... fluid dynamics sounds great. Maybe someone will post some amazing dyno results to quiet the onlookers..... I'm getting full of popcorn
Old May 24, 2008 | 04:01 PM
morbius's Avatar
morbius
Dr. Morbius
Ok, I am done. You all win. Cheers.
Old May 24, 2008 | 04:05 PM
no need to run off, people are just looking for hard data on the dyno or track
there has been so much butt dyno error to throw out any data based on "feeling"
Old May 24, 2008 | 04:07 PM
Guest's Avatar
Guest
I was just saying... 14 psi is a bit unrealistic. These cars push between 11 and 12 PSI of boost depending on temperature, and slightly more with the DSC off.
I'm with PGT on this one though, how do you measure boost at part throttle? There's no way to compare part throttle boost unless you can actually give raw numbers for the % throttle you were using.
Saying "I pushed the pedal down a bit and got 7 psi, and I did it again after the AGS and got 9" is about as unscientific as it gets...
