Drivetrain oil cooler
Old May 18, 2008 | 02:17 PM
spam052's Avatar
spam052
oil cooler
so im interested in an oil cooler for the r56. but this is the firs time i will be dealing with this type of mod. so could you guys please recomend me a good brand and where should i place the radiator for it? thanks for the help.
Old May 18, 2008 | 04:54 PM
SlowB00st's Avatar
SlowB00st
the problem here is that normally the oil feed/return would have been taken from the oilfilter with a sandwich adapter and the cooper oil filter is just a refill. I know some time back someone made an adapter for the R53 would be nice to have something like that for the R56.
But for those that are conserned with warranty/mantainance plan by adding the oil cooler it will be another story...
It would be nice to be able to do it since I have a mocal oil cooler from my previous car would just need to swap a few parts.
Old May 18, 2008 | 08:53 PM
spam052's Avatar
spam052
i was on the web looking for that and found that there is an adaptor for the m3 but i don't know if it will work on the mini here is the link http://www.bimmerworld.com/html/vpd-...oil-cooler.htm
Old May 18, 2008 | 10:00 PM
Longboard Mini's Avatar
Longboard Mini
I know it's crazy but RMW is finishing up their new oil cooler.
oops, sorry it's for the R53.
Longboard
Old May 18, 2008 | 11:33 PM
Guest's Avatar
Guest
Longboard
Hopefully soon, I need to get it installed before the track!
Old May 19, 2008 | 08:38 AM
Bhatch's Avatar
Bhatch
http://www.realoem.com/bmw/showparts...30&hg=11&fg=30
this is a link to the stock R56 oil cooler, you can see that there is a external chamber mounted with two rubber o-rings. It should be possible to replace part 4 (heat exchanger) with a remote one.
Old May 19, 2008 | 10:47 AM
spam052's Avatar
spam052
mini madness has a part that replaces the heat exchanger and connects it to a oil cooler. i was hoping that it was compatible with the r56 but mini changed the shape of the heat exchanger so no dice .
Old May 19, 2008 | 12:21 PM
scabpicker's Avatar
scabpicker
Does anyone have any info on if the stock one is efficient enough? I haven't seen a lot of data on oil temps in the r56, (yeah, I need to get my own gauges). and had up till now assumed the stock oil/water heat exchanger was sufficient.
Old May 19, 2008 | 05:57 PM
ScottinBend's Avatar
ScottinBend
The stock system is more than adequate for daily driven cars, even with some track days thrown in. In my R53 I never saw temps above 240 F on my track days and never above 210 F when driving around town or in the twisties.
Just make sure you are using a quality oil.
Old May 19, 2008 | 09:06 PM
Guest's Avatar
Guest
My oil temp on the street hits 225 if I'm driving hard. On the track, 280-300 easy.
The Oil "Cooler" is fed engine coolant. It doesn't really help in keeping oil temps below 200 when your coolant is at 230...
Old May 19, 2008 | 09:16 PM
ScottinBend
What oil are you running..........
I have never seen temps that high. Highest was maybe 250 F last track day and ambient was 80 F. And I can barely get my oil above 210 F on my "fun" drives.
Old May 19, 2008 | 09:19 PM
Guest's Avatar
Guest
Factory MINI oil. The temperature differences probably have something to do with that, but it's not localized to my car. Most of the cars out here with 230+ whp are pushing high oil temps. I was also revving the car up to 8250 RPM's at the time, which probably didn't help.
Old May 20, 2008 | 07:12 AM
ScottinBend
..............ya think !
Old May 20, 2008 | 10:53 AM
Guest's Avatar
Guest
Still seeing 225+ degree intake temps on the street. I'm sure the 118 degree heat doesn't do a whole lot to cool it off...
Old Jun 28, 2008 | 01:52 PM
Calaway16's Avatar
Calaway16
I have a stock R53 MCS and am at the track at this very moment. Today I was seeing temperatures at the top end of my oil temperature guage in the Chrono Pack (320F). Ambient temperatures are HOT. 95-100 degrees. I definitely need to look into an oil cooler. My engine temperatures looked normal oddly enough.
Old Jun 28, 2008 | 01:56 PM
Guest's Avatar
Guest
Give Jan a call. He's working on one. Might be complete now.
On the highspeed track I went to last month I saw pretty stable oil temps in the 250 range. Low speed tracks I'm usually 280+.
Old Jun 28, 2008 | 05:06 PM
Bhatch's Avatar
Bhatch
Oil does not break down until 400+ F.
Flash point for Mobil 1 10-40 is like 420. The MOTUL i use is 460F.
Old Jun 29, 2008 | 05:40 AM
Calaway16's Avatar
Calaway16
I run Castrol 5W-30 from the dealer (We just did our own oil change this weekend). I still would prefer my oil to be a tad cooler. But that is good to know. Thanks a lot!
Old Jun 29, 2008 | 10:45 AM
user 7082082's Avatar
user 7082082
I run the M7 thermostat and my oil is @ 180-190 degrees when I am taking it easy on the streets. However, once I start pushing the car it gets hotter again so I might either swap it out soon or waite until I buy an oil cooler from RMW.
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
zip251
Aug 30, 2015 07:15 PM
shark715
Aug 30, 2015 07:01 PM
Aug 11, 2015 09:01 AM
