Drivetrain OEM LSD vs Quaife
Old Apr 9, 2008 | 07:26 PM
PlayPlay's Avatar
PlayPlay
OEM LSD vs Quaife
My 2006 JCW came with LSD. Would there be any benefit to getting a Quaife LSD? What exactly is the difference? Thanks...
Old Apr 9, 2008 | 07:30 PM
silversmoke06's Avatar
silversmoke06
Far as i know the quaife is better but i dont know that for sure
if you do infact want to do it and have the left over stock lsd ill buy it from you
Old Apr 9, 2008 | 07:34 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Damn, you got to him first.
Old Apr 9, 2008 | 07:43 PM
silversmoke06
good timing i suppose. im pushing 205 to the wheels its borderline explosive with the wheel spin.
Old Apr 10, 2008 | 01:22 AM
Berthil's Avatar
Berthil
The Quaife is a full cogg-wheel differential and is in fact not a LSD because nothing 'slips' there. The Quaife therefore has no wear because it is not based on a slipping principle, it does not need servicing like de Mini LSD does (replace worn plates, change oil).
The Quaife also does his job up to 80%, the LSD only to 30% (so the Quaife wil send up to 80% of the available traction to the wheel with the most traction, the LSD only 30%). I also understand that the Quaife does not do his job anymore if one wheel lifts completely of the ground an the the LSD does so the Quaife is not suited for very bumpy roads.
Upside is that Quaife gives a lifetime warrenty, downside is that the cog wheels make more noise.
Old Apr 10, 2008 | 06:23 AM
PlayPlay's Avatar
PlayPlay
2BeeMini2....thanks for the awesome explanation!
Silversmoke & Nabeshin: Sorry you two, based on the explaination, I probably won't be replacing anytime soon!
ej
Nov 17, 2015 09:21 PM
Anakist
Sep 23, 2015 08:05 PM
vargasgal
Sep 17, 2015 10:02 AM
giovanni cerchiara
Sep 15, 2015 07:08 AM
Ladybug-S
Sep 10, 2015 07:08 PM
