Drivetrain OBX ATB Diff, Clutch, and Cam
Old May 5, 2008 | 07:49 PM
  #51
jhiggs26's Avatar
jhiggs26
Yeah I'm on holidays this week so this is my down time before my wedding later on this month(my 1st baby due in late Sept too--- ).
I plan on installing the phantom grip in my stock open diff and putting it up for sale(as long as my cross pin has no slop/wear).
How's your new RMW camshaft treating your MINI Longboard?
Jeremy
Old May 5, 2008 | 08:03 PM
  #52
Longboard Mini's Avatar
Longboard Mini
Jeremy
Congrates on the wedding and the little one the way. I have four kids .
The car is still up at MiniCorsa. I should get it back this week. The head on my car was the first RMW head. The productions units had a couple things mine didn't so Jan's fixing that while we have the head off. Danny's also adding a new oil pump, IE fixed camber plates and fixing a bad sensor.
Once I get it back Jan's going to tune it then I get to play.
Bryan
Old May 5, 2008 | 08:17 PM
  #53
jhiggs26's Avatar
jhiggs26
Ahhh shucks, I thought you would have had your MINI back by now and ripping up the pavement. I
'm glad that Jan's tweaking your pre-production RMW head and tuning it yet again. A bunch of us are awaiting results from the Project X-300 thread!
Adding a little more negative camber up front should be in my future too!
Jeremy
Old May 5, 2008 | 08:45 PM
  #54
Longboard Mini
Ya, Jan is a stand up guy.
Add me to that bunch that's waiting for results . Seriously though Jan has been so busy that I have taken a back seat so many times I forgot how long this project has taken. I am really excited to get it back as this should be it!! I have some killer dyno sheets but until it was finished I chose not to share. I will now as we should be done.
Longboard
Jeremy
Old May 5, 2008 | 09:11 PM
  #55
Trickle X's Avatar
Trickle X
Looking good Jeremy...congrates on the fam too!
Old May 6, 2008 | 10:35 AM
  #56
jhiggs26's Avatar
jhiggs26
Originally Posted by Ryephile
Jeremy,
If you get a chance please weigh your stock diff! I forgot to weigh my stock and Quaife Rev2 and it's driving me up the wall! I know K-huevo weighed both Quaife's at one point and the Rev2 was 2 lbs 6 ounces less; your OBX should weigh similar to the Quaife Rev1 I'd imagine since it's a copy of it.
We use the same weighing method (me+parts and then parts alone to verify] My scale came up with 12 pounds for the CM flywheel and 26 for the stock dual-mass flywheel. I remember the CM FX200 being 1 pound heavier than the stock clutch/flywheel.
Are you pulling the whole powertrain or just the tranny? I can't decide which is harder, both methods suck!
Ok Ryan my stock open diff is about 15 pounds with the crown wheel gear and stock diff bearings still mounted! I'll weigh the OBX when I get the bearings and crown wheel gear bolted up.
The red loctited diff bolts(M10 by 1.5) from the factory let loose between 50-65 ft-lbs. I thread restored them and hit them with brake cleaner. I'll have to find the correct tourque setting for those bolts now, before I snug them up! I think K-huevo did them @ 70 ft-lbs.
I just baked my new diff bearings for 20 minutes at 350 F, and they slide right down onto the OBX diff! I was ready with a 1/2 drive extension mounted inversely to a 36 mm socket to go to work with a BFH, but there was no need!
Jeremy
Old May 6, 2008 | 01:12 PM
  #57
MiniMacPR's Avatar
MiniMacPR
Nice thread Hope you get to enjoy your new goodies soon...
Old May 6, 2008 | 05:23 PM
  #58
jhiggs26's Avatar
jhiggs26
Yeah I hope to enjoy these goodies soon MiniMacPR!
I'll be off shopping for wedding attire tomorrow afternoon, but I hope to mate the gearbox to the motor before I leave.
I torqued up the thread restored diff bolts and torqued-in 10 ft-lb steps-from 30 ft-lbs up to 60 ft-lbs. Oh yeah and the diff bearings were baked at 350 F for 20 min and they dropped right onto the new OBX diff! I'm thinking 70 ft-lbs may be excessive for the short M10 by 1.5 bolts even though they are grade 12.9. Pics below.
Jeremy
There's the 6 speed bell crank shaft at the top. Too bad reverse gear on the left is in constant mesh with 1st gear. What a power soaker. :-( Trans is in neutral now because of detent spring pressure, and ready in the 3rd-4th gear plane because of the giant spring at the left end of the bell crank shaft!
New bearings and crown wheel gear cleaned and blown off. Bearings are ready for a warm up in the oven!
Diff bearings on OBX without incident! I had a 36 mm(oil filter socket) with a 1/2" drive extension mounted inversely on hand to BFH the bearings on the diff if need be.
Side shot of course.
There's a standard 3.44:1 crown wheel and pinion from a Mini on the left for comparison. haha
New diff snugged up for a final torque up!
Old May 6, 2008 | 07:48 PM
  #59
Ryephile's Avatar
Ryephile
Jeremy
Keep up the great work!
Thanks for the weight statistic, I'm very curious to know how much the OBX diff weighs in comparison. Then the only question will be how much does the Rev.A Quaife I have in my car weigh, as I forgot to weigh my stuff during my recent install.
Cheers,
Ryan
Old May 6, 2008 | 09:20 PM
  #60
k-huevo's Avatar
k-huevo
Original Quaife 14lb 2oz
Old May 6, 2008 | 09:58 PM
  #61
Guest's Avatar
Guest
Originally Posted by Longboard Mini
Dude, Danny was running Jan's old Phantom grip for a long time. Between the power Jan put through it with his old twin charge car and beating Danny put it through I would give it big for reliability. Yes, Danny finally killed it but that thing lasted a hell of a long time.
I have 10k miles on my OBX and love it. Didn't do anything other then drop it in. So far so good .
Longboard
I think it's a clutched diff... rather similar to the stock one. I was just saying that the geared design from the OBX/Quaife is better (Doesn't wear out).
Old May 7, 2008 | 06:44 AM
  #62
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
So, what do you all recomend...OBX or Quaife???
If I would have the money for either, would I know a difference?
Do they handle different amounts of power?
Old May 7, 2008 | 09:23 AM
  #63
jhiggs26's Avatar
jhiggs26
Cheers,
Ryan
Ok Ryan,
I weighed the OBX diff in at about 20 lbs with crown wheel gear and both diff bearings. Note: My scale is a bathroom scale so the error is likely (+-)1 pound with all the measurements I've taken in this thread. Anyways, the upshot is that the OBX ATB diff is about 5 lbs heavier than the stock open diff.
Here's a few videos I quickly made up this morning while my coffee was brewing.
Shift Mechanism
http://www.youtube.com/watch?v=07uRhOnk3h8
Getrag Gearset
http://www.youtube.com/watch?v=OmBJ03-OEfo
Reverse Selected
http://www.youtube.com/watch?v=6gLvJFiFRZk
Now for a final surface prep before I lay down a bead of sealant and close in the trans. BTW the trans magnet was in great shape with just a star shaped sludge of ultra minute metallic particles!
Jeremy
Old May 7, 2008 | 09:47 AM
  #64
kgardnez's Avatar
kgardnez
What are your plans for checking gear mesh and/or shimming the differential? (I've been trying to figure this part out for my install)
Old May 7, 2008 | 09:54 AM
  #65
jhiggs26's Avatar
jhiggs26
Gear mesh should be ok(stock crown wheel gear still being used), as long as the OBX and the stock open diff cases are the same length. Perhaps I should check that over. haha I didn't replace the outer diff races but they look AOK with I'm hoping close to zero wear. I'll go compare before I bolt her up! If it's under a few thou difference I should be ok!
Jeremy
Old May 7, 2008 | 06:37 PM
  #66
Guest's Avatar
Guest
Danny has an OBX, I have a Quaife, we lined them up side by side, aside from a few washers (which he stuck in his) they're identical. The cost didn't matter for me, so I went with Quaife. OBX is the same thing.
Old May 7, 2008 | 06:49 PM
  #67
kgardnez's Avatar
kgardnez
Quaiffe vs. OBX I think 90+% you will find no difference, I bought a used Quaiffe simply for a little more piece of mind... .but I do wonder if I over spent and should have gone with the OBX (though I wonder on their customer support)
Old May 7, 2008 | 09:48 PM
  #68
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Thanks Rusty and kgardnez
Depending on money...I will go with the OBX...
Old May 7, 2008 | 10:08 PM
  #69
jhiggs26's Avatar
jhiggs26
Chris read my Post # 7. Make sure she's all good to go before you throw it in!
Today, my Dad managed to help me align the trans with the motor and bolt her back up. It got a little tense but after 25 minutes or so and a slight rotation of the crank, the input shaft slid into the clutch disc! Bingo!
A few pics from today.
Jeremy
Trans side of flywheel housing all clean and ready for new seals.
Cleaned up and ready for a new guide tube, input shaft seal and clutch release bearing.
Even Steven here.
Even Steven there.
Smooth bead.
Old May 7, 2008 | 10:11 PM
  #70
jhiggs26's Avatar
jhiggs26
Kgardnez see pics above. Everything seems spot on!
Has anybody out there had to shim their Quaife or OBX diff????
Jeremy
Old May 8, 2008 | 04:45 AM
  #71
J Propane's Avatar
J Propane
What kind of sealer did you use?
We normally use an anaerobic sealer.
Old May 8, 2008 | 05:00 AM
  #72
kgardnez's Avatar
kgardnez
When you have a chance, could you list the parts you replaced and why.
Old May 8, 2008 | 06:24 AM
  #73
jhiggs26's Avatar
jhiggs26
I used Permatex Ultra Black J propane.
Kgardnez I did the input shaft seal and guide tube just because I was there. My guide tube was scored up a bit so why not replace it. Next time I do a clutch on this MINI I'll replace the plastic bushings for the clutch release shaft(they're ok now). Your clutch kit will most likely have a release bearing included. I replaced the output flange seals for the half shafts(no new diff fluid is going to get swept out of case). I didn't replace the rear main oil seal as it looked fabulous. I finally installed my transmission mount powerflex insert because the mount was off the car anyways. I'll need some heat resistant tubing to cover up my nylon oil pressure line that runs near the exhaust manifold. The wimpy plastic tubing I put over the line was melted pretty bad. It lasted for a year though! I've also got a fastener set from MINI Yaletown to use when I install the front subframe/suspension. Finally I've got powerflex sway bar bushings, steering rack bushing, and lower control arm bushings(my stock bushings look pretty good though). I think that's all.
Jeremy
Old May 8, 2008 | 08:49 AM
  #74
Some Guy's Avatar
Some Guy
Gear shimming, I know how to do that on airsoft guns, but how would you shim the dif if you had to?
Quick question, what torque values did you use for bolting the two halves of the gearbox together?
Old May 8, 2008 | 12:11 PM
  #75
jhiggs26's Avatar
jhiggs26
You'd have to shim in between the diff case and the inner race of the diff bearing. Luckily OBX measured correctly, or so I hope!
I tourqued the flywheel housing to the gearbox at 27 ft-lbs. The bolts are M8, cadmium plated and are going into aluminium. I thread restored all of the bolts(I think there are nineteen).
Jeremy
