Drivetrain squeaking when cold with M7 16% and JCW belt
ever since i had the pulley changed, the s/c belt squeaks til about the temperature on the speedo reaches 1/4 from a cold start. if i leave it for anything more than an hour and it squeaks from the start (but quickly disappears after about a few seconds) i've done about 7,xxx kms with the pulley and jcw belt and it has always been like this.
i had my Mini dynoed about 3-4 months ago, boost was consistent so i'm guessing that my belt's tension is just right (if it were loose, it should be jumping right?)
I change to NAPA 25-060-535. No more slippage.
I had this with my 16% and stock belt so figured it was a good time to replace the belt. Went with the one that Chad at Detroit Tuned sell/recommends (along with a tensioner strap for protection) and I've had no noise since.
Do a visual check of the tensioner holes, there's a picture around here somewhere for reference. You should have at least half a hole showing. I use the 535 size with a 15% because it was slipping before with the previous belt. Not any more.
Also, check alignment as well. If the pulley is off by a fraction, it will warm the belt to stop squeeking after a bit, and then stay quiet. Easy to check as well if you are in there poking around!
Dec 23, 2015 10:36 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
