Drivetrain Forge Blow-off
Old Nov 14, 2007 | 10:23 PM
  #26
T18DRYVER's Avatar
T18DRYVER
THE BOV RELEASES WHEN YOU LET OFF THE THROTTLE, THE WASTE GATE REGULATES TURBO PRESSURE!
Old Nov 14, 2007 | 11:26 PM
  #27
msh441's Avatar
msh441
Originally Posted by msh441
As I take a close look at that last pick and scavenge my memory... I would say that yes, you are correct! That last pic in the Forge instructions looks like it's on backwards .
I asked Forge about their instructions and got this as a reply:
Sir,
As is noted in the instructions, this particular photo is used for illustration purposes only to show where the spacer mounts.
It will obviously need to be installed in the opposite facing direction so as to facilitate reinstallation of the OEM valve on top of the spacer.
Kind Regards
Mike Lombardi
Forge Motorsport US Inc.
6536 Pinecastle Blvd. Suite C
Orlando FL 32809
407-447-5363
407-447-5361
mike@forgemotorsport.com
www.forgemotorsport.com
So I think the "official" reply from Forge USA was: "Duh! Of course it's backwards!"
Originally Posted by LexusIS-F
Can anyone give more detail about the Forge BOV, does go off when you let off the gas? or it goes off on higher RPM? please provide more info. anyone... thanks
Yes it vents when you lift off. Higher RPM makes more boost and therefore a more noticable hissing noise. Just putting around town, though... pretty quiet IMO.
Old Nov 14, 2007 | 11:27 PM
  #28
Konquest's Avatar
Konquest
nice job haha, I love how he said "obviously"....
Old Nov 24, 2007 | 11:54 AM
  #29
LexusIS-F's Avatar
LexusIS-F
Quick question on installing the Forge Spacer. Do you really have to remove the radiator fluid tank to have room? Does anyone that install their Forge BOV w/o removing their radiator tank? plmk. thanks
Old Nov 24, 2007 | 04:11 PM
  #30
T18DRYVER's Avatar
T18DRYVER
Just installed the forge BOV this afternoon. Started at 2:08, tools put away and closed the hood at 2:38, piece of cake, 1 flat blade screwdriver, 1 3/16 allen wrench(or metric equivalent) and a 8mm socket to remove the radiator reservoir. complete removal is not necessary, simply remove the top hose, leave the bottom attached, remove the 8mm screw at the top, unclip it and move it to the side. no fluid spill, no mess with a cold engine. Pay attention to the hose clamps on the intake pipe, they are indexed to the pipe. The sound is fun when you push on it and subtle enough when you are taking it easy. No real performance added but a cheap thrill for $69 and a simple removal if you don't like it or need to pass a smog check.
Old Nov 24, 2007 | 05:45 PM
  #31
porkchop's Avatar
porkchop
Stupid question...
Why would a BOV effect your exhaust? You're blowing off the excess compressed atmosphere before it gets to the engine, right?
Last edited by porkchop; Nov 24, 2007 at 05:47 PM. Reason: added quote for clarity.
Old Nov 24, 2007 | 07:47 PM
  #32
T18DRYVER's Avatar
T18DRYVER
IF YOU ARE ASKING ABOUT PASSING A SMOG CHECK IT IS BECAUSE WE ARE NOT ALLOWED TO VENT TO THE ATMOSPERE, MUCH LIKE OPEN ELEMENT AIR FILTERS WILL NOT PASS SMOG IN CALIFORNIA. ACTUAL EMMISSIONS FROM THE TAILPIPE ARE NOT AFFECTED BY THESE MODS AT ALL, BUT WITHOUT C.A.R.B. APPROVAL WE CAN'T PASS SMOG WITH THESE ITEMS INSTALLED
Old Dec 2, 2007 | 10:29 AM
  #33
SomethingNew71's Avatar
SomethingNew71
I just ordered mine will post a video upon installation.
Old Dec 2, 2007 | 05:23 PM
  #34
T18DRYVER's Avatar
T18DRYVER
Piece of cake! like I said it irs subtle unless you are hard on the throttle. Time yourself and let us know your time to install.
Old Dec 6, 2007 | 05:46 PM
  #35
SomethingNew71
Here is my video of the Forge BOV. Enjoy. It took 23 mins to install. (timed it) So far I love it. It doesn't get really loud until the higher RPM's so it's not bad at all in regular traffic. It does turn a few heads though.
http://www.youtube.com/watch?v=apd8b3EyiNc
Old Dec 6, 2007 | 06:17 PM
  #36
LexusIS-F's Avatar
LexusIS-F
Where is the video? Can you post the link? thanks
Old Dec 7, 2007 | 11:32 AM
  #37
torobud's Avatar
torobud
wow... this is trouble for me...
Mopar makes the same kind of piece for the SRT-4 which I installed on both of them that I had...
Damn this might be my next thing...
Old Nov 10, 2010 | 06:04 PM
  #38
bbm's Avatar
bbm
Originally Posted by Konquest
question: i installed the forge blow off using the instructions from the Forge website, on the last picture the blow off has the inner tube facing out. Is this how its supposed to be installed? When I put mine in I placed the blow off with the inner tube facing in so its like: pipe <-- blow off <-- solenoid.
http://www.forgemotorsport.com/media/FMDVMCS.pdf
You are absolutely correct. That last picture is has the inner tube facing the wrong way. I can not belive Forge has not corrected that instruction on there web site.
Old Nov 10, 2010 | 06:21 PM
  #39
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes it's backward in the picture.
If you have a long allen wrench or socket then you can get to the screws without taking any of the hoses off. Just pull the coolant tank out of the way that's how we install the Forge BOV adapters.
Old Nov 14, 2010 | 10:42 AM
  #40
MattyKHZ's Avatar
MattyKHZ
I was at Forge 2 weeks ago as they needed a R56 to test fit some parts, which resulted in me getting to keep them.
They have a new actuator for the turbo which they fitted to mine:
http://www.forgemotorsport.co.uk/con...product=FM207V
I was asked if I wanted to hear it or not and thinking it was a dump valve I said not so they left the spacer of which makes the noise. Still works as it should just without the noise.
Got the intercooler pipes and induction pipe fitted whilst I was there.
Old Nov 15, 2010 | 04:20 PM
  #41
AstroBlackBeast's Avatar
AstroBlackBeast
$69 @ Forge
Question: Where did you see it for $69? They are listed for $80 everywhere. Not to sound like a tool or anything but the cheaper the better haha
Old Nov 16, 2010 | 08:57 AM
  #42
sunman's Avatar
sunman
So how does the Forge BOV/uprated valve differ from the HKS BOV besides the location of the BOV's - Hope this makes sense
NYMADMINI
Dec 14, 2016 02:33 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
micromini234
Sep 30, 2015 07:36 PM
