Drivetrain HELP SUPERCHARGER HOW TO
Old Aug 13, 2007 | 09:17 AM
4GAZM's Avatar
4GAZM
hello all well i finally got my port and polished supercharger and just wanted to know ware i can find a how-to to remove the supercharger and all, i can prolly do it myself just by getting in their but i was hoping maybe their is a link to a how to, to make the job a little less scary
thanks
chris
Old Aug 13, 2007 | 10:25 AM
CHILE_RED's Avatar
CHILE_RED
I do not believe there is a how to on how to replace the supercharger but once you look at how it is on there you will come to realize that it is pretty simple.......
Old Aug 13, 2007 | 10:41 AM
4GAZM's Avatar
4GAZM
cool thats what i needed to know i was just wondering if their were any tricks that i shoul look for or any thing that i was not expecting to jumo out at me !!!
also will i be able to replace the supercharger without taking of the waterpump or will that have to come off two thanks
Old Aug 13, 2007 | 10:51 AM
Eric_Rowland's Avatar
Eric_Rowland
Water pump is bolted to the SC, so unless your P/P SC already has a water pump attached, you'll be removing it.
Old Aug 13, 2007 | 11:47 AM
k-huevo's Avatar
k-huevo
Randy Webb’s original pulley swap method will give you a general idea http://store.webbmotorsports.com/for...topic.php?t=16
Some steps can be omitted from his approach; here is an overview of my method: drive up on ramps, disconnect the battery, remove the bumper cover and bumper, unbolt and remove the crush tubes, unclamp the lower coolant hose to the radiator and drain, disconnect the upper coolant hose, disconnect the fan and unbolt the refrigerant line from the chassis, carefully bend the AC heat exchanger down and away from the radiator support, remove the radiator support and drain the remaining coolant, remove the intercooler, it will now look like this
take tension off the belt, lock in place and unbolt the arm from the supercharger, remove the center coolant hoses (one big & one small), remove the throttle body and supercharger intake duct, remove the dip stick tube if you can (I had to move the SC upwards but others have been able to remove the tube first), remove the alternator and unbolt the SC, however you are able to get the dip stick tube out be sure to plug the hole before pulling the supercharger, attached water pump & supercharger output duct away from the block because coolant will flow directly over the opening, the block will now look like this
As can be seen I do not remove the fuel lines or intake manifold.
When installing the SC, rub KY on the new water pump o-ring, insert the input tube carefully, when threading the tensioner arm bolt back into the SC take tension off the arm’s pivot point with a prybar so there is no side load on the bolt.
I’m sure something has been omitted so feel free to ask if there is a gap in understanding.
NYMADMINI
Dec 14, 2016 02:33 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
patsum
Sep 30, 2015 02:10 PM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
