Clay Bar Remove Overspray?
Old Apr 25, 2007 | 08:52 AM
rc'S's Avatar
rc'S
Have some overspray on my new MINI. Used a razor blade to get it off the windshield. Did well no blade scratches on the glass. I used the sandwhich baggy trick that Heather told us about to feel how rough the paint is. Holy mackeral, it was unbelievable. A couple of my friends could not believe it either. Will the clay bar take the overspray off the paint before I buff/pc it?
Old Apr 25, 2007 | 09:03 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Yes, but you are going to have to work the clay pretty hard, for a long time. Just keep spraying your QD every once in a while and keep claying. You might be looking at a little while per section depeding how much over spray your looking at.
Old Apr 25, 2007 | 09:42 AM
ImagoX's Avatar
ImagoX
Clay bar is actually perfect for this, as Jeremy said. Just keep going - clay when used properly doesn't SEEM to be doing anything right away - it glides across the surface and doesn't "feel" like anything is being removed.
It is though, trust me! I just got some tar marks off my Suburban with clay that resisted everything I tried. It took about 15 minutes per black mark and several hundred passes, but eventually it let go. Just work slow and check often and you'll be fine.
Old Apr 25, 2007 | 10:09 AM
MiniMaybee's Avatar
MiniMaybee
This is what clay was originally intended - remove overspray. There are different grades of aggressiveness so if you don't want to rub your arm off you might see if you can find a clay with more bite than detailing clay.
dirtyscarab
Aug 23, 2015 07:50 PM
greekzilla
Aug 23, 2015 03:44 PM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
