HELP! Scratched black plastic trim.
Old Jun 5, 2004 | 04:06 PM
keddell's Avatar
keddell
A fear of mine has finally come to pass. While getting his bike from the garage my son accidentally put a scratch in the left rear black fender trim (missed the paint - yeah!). I feel bad. He feels worse. What's a dad to do? I've told him not to worry, I'm not mad.
Now what can I do to make it (sorta) go away? Is there anything that will cover it up?
Calling all experts... You are my only hope. Many thanks.
JK
Old Jun 5, 2004 | 04:13 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
If the scratch is not too deep you can either sand it out with really fine 400 to 600 grit sandpaper and finish it with a vinyl or rubber treatment product or just try treating it with the vinyl product directly if it is superficial.
I use Zaino vinyl and rubber treatment solution and that works pretty good. You can check the older posts to see the other products people use on the wheel arches to keep them looking new.
If the scratch is quite deep then you will need a coarser sandpaper first then work up towards finer sandpapers and then finish with the 600 grit. you're only trying to smooth the scratch out a bit not remove every last bit of it or you will make the finish entirely smooth which won't match the slightly textured surface of the wheel arch.
good luck.
Old Jun 5, 2004 | 04:48 PM
d-mini-ero's Avatar
d-mini-ero
Simply call your local MINI dealer.
The plastic pieces are inexpensive... the total which is approx (13) pieces ...are less than $150.
If I recall correctly....the piece you're in need of is approx $12.
Peace,
D
_________________
PM d-mini-ero
Old Jun 5, 2004 | 04:54 PM
lotsie's Avatar
lotsie
>>Peace,
>>D
>> Thats good to know,mine are getting rough from gravel,now I do have those fancy new mud flaps,although $12 U.S. in about 2k Cnd. _________________
>> PM d-mini-ero
Old Jun 5, 2004 | 04:58 PM
minihune's Avatar
minihune
Sure, replacing the part is fine if it is deeply scratched.
Or a few cents for the sand paper is not bad either.
Don't worry, be happy. :evil:
Old Jun 5, 2004 | 05:10 PM
keddell's Avatar
keddell
TWELVE BUCKS!? Are you serious? I didn't think there was anything automotive left anymore that didn't cost hundreds of dollars!
I will definitely look into that. I will also probably invest in some sand paper and rubber/vinyl treatment, stuff I should have around anyway. In addition, this is one more sign that I need to organize the garage...
Many thanks to all for the advice.
Joe
Old Jun 5, 2004 | 05:31 PM
JustGo4It_'s Avatar
JustGo4It_
The trim is textured. Sanding it will mave it smooth and "fugly". Don't waste your time. Buy a new piece.
Old Jun 5, 2004 | 06:50 PM
911Fan's Avatar
911Fan
I vote for buying a new piece too.
I'm curious -- is the trim piece solid black plastic or is it just painted black?
Old Jun 6, 2004 | 07:34 PM
BuckeyeMCS's Avatar
BuckeyeMCS
I am for buy a new piece as well
G1HQ
Dec 7, 2015 02:23 PM
SunnySideUp
Aug 28, 2015 06:52 AM
WayMotorWorks
Aug 4, 2015 01:47 PM
