Wheel well slush removal / winter cleaning
Old Nov 21, 2013 | 04:12 PM
Travelin_MINI's Avatar
Travelin_MINI
So it snowed in Denver last night and my poor Rudy is all dirtyand plenty of the road crud/slush has built up in the wheel wells. Anyone have some good tips on how to keep my car looking somewhat clean and getting rid of the build up of slush? Thanks in advance!
2009 Mini Cooper Hot Chocolate Clubman "Rudy"
Old Nov 22, 2013 | 05:59 PM
Super Coop's Avatar
Super Coop
Easiest way is to a power washer. You don't have to go crazy and hold the nozzle an inch away from the fender well, just get it close enough to take off the slush. Afraid of or don't have a power washer? Jack up each corner, remove the wheel, and use a brush.
Old Nov 24, 2013 | 03:21 PM
LoganB92's Avatar
LoganB92
Im in the same boat down here in colorado springs, i just take it to the local car wash and spray it down enough to get all the crap off, then wipe it down to the best of my ability
Old Nov 24, 2013 | 06:16 PM
BRGPA's Avatar
BRGPA
Slide an oscillating lawn sprinkler under each corner and let it use lower pressure to lift and remove the crud. I do this each spring, but it should work in winter, too, if you have access to a hose & sprinkler.
Old Dec 22, 2013 | 05:04 PM
e46jb's Avatar
e46jb
This will only work in some markets. I believe where he is located, the weather is below freezing for extended periods of time and water will not flow through a hose since it would be long frozen.
Old Jan 11, 2014 | 06:26 AM
TorchMINI's Avatar
TorchMINI
Sorry that I didn't see this thread before starting a similar thread about salt buildup. I have to use a nearby power sprayer, but there's places up under the engine and front wheels I can't seem to get in time to stop rust. We too have no home hose options for many winter months, but that sprinkler option sounds good!
All that said, my Clubman is a fabulous winter driver with its dedicated snow and ice tires, Hakkapellitta R.
phrza81
Oct 10, 2015 11:37 PM
minipopkart
Aug 13, 2015 05:22 AM
ludedude
Aug 10, 2015 07:16 PM
Dashdog
Aug 10, 2015 06:17 AM
