Pine Pitch: 2, GooGone: 0.5
Old Apr 18, 2010 | 01:46 PM
robinj's Avatar
robinj
yeah, um... I parked under a tree the other day that was dripping pitch apparently. I finally got around to trying to remove it and googone only got rid of like 1/4 of it. there's several really, really thick splotches that the goo can't penetrate so I was thinking of "alternate" methods:
would LAVA (pumice) soap be too abrasive and leave a mark on my windshield?
leave goo gone on until it dries up, but with it dripping the way it does that would be difficult
Thermite would work but I don't have any on hand and would need to be careful I have a car after. And yes, I watch too much Myth Busters...
Old Apr 18, 2010 | 05:51 PM
tedswoods's Avatar
tedswoods
I had a similar, no actually completely different problem the other day. I had some new energy efficient windows installed last fall at my house. Had a heck of a time getting the adhesive from the labels off. Mind you the labels themselves came right off; it was the adhesive that wouldn't budge. Just last week, I thought to do a search on here. Someone (actually a few someones) said WD-40 would work. I was dubious, but it worked really well! I don't know about how it might / not do on pine pitch, but it worked great on 4-5 month-old adhesive from window labels that nothing else would help on.
Good luck to you!
Old Apr 18, 2010 | 06:07 PM
moreorless's Avatar
moreorless
Yep. I go the WD-40 route. It even takes off the white paint they spray the lines on the roads with.
Or you can try a clay bar. That thing takes off a lot of different stuff.
Old Apr 18, 2010 | 07:38 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
If it is on your windshield, use a straight utility razor blade and scrape it off.
Old Apr 18, 2010 | 09:16 PM
robinj's Avatar
robinj
hmmm, I think I'll try the WD40 route next...
thanks
Old Apr 22, 2010 | 08:57 AM
Timmer2009's Avatar
Timmer2009
I had blue paint spatters all over my door and the molding
Tried WD 40 to no avail,
I them tried a can of disk brake cleaner. I had some residue after getting the blue paint off. Washed the door and got my wax out. Thank GOD everything looks pretty good again.
The only thing that would take this blue paint off the plastic was carb cleaner. It cleaned up just fine.
Old Apr 22, 2010 | 09:00 AM
mmatarella's Avatar
mmatarella
Yea brake cleaner will destroy paint...
How about Hot water, to soften up the pitch?
Edit: After I posted I googled it... See a bunch of ideas at http://www.thriftyfun.com/tf697215.tip.htm Mayonnaise!?
Old Apr 22, 2010 | 12:38 PM
Daddy_Rabbit's Avatar
Daddy_Rabbit
hand sanitizer ... seriously
Old May 18, 2010 | 12:59 PM
twistdpair's Avatar
twistdpair
You know why? Isopropyl alcohol in it. Thus, a cheap bottle of rubbing alcohol will absolutely do the trick.
My wife parks under a large pine, and I had about 25 little pools of sap GONE in about 30 minutes. Plus...no worries re: paint.
Old May 18, 2010 | 01:04 PM
Daddy_Rabbit
ok
oPossum
Electrical
109
May 9, 2026 05:40 PM
Keet
Suspension
Aug 30, 2016 03:46 PM
Sep 1, 2015 04:39 PM
Accessory Products
Aug 25, 2015 10:03 AM
Dashdog
Aug 10, 2015 06:17 AM
