Banana GAS ?? I don't know... maybe Nick tried to drink some and the result was.......................
CR&PW&JB&&&, you beat me to it '
Got mine today too!!!! Guess I need to get to work.
I beat you to the punch line but you're going to beat me to using the BG. I have to wait until the next time I wash one of mine. Probably tomorrow evening.
Quote:
Quote:
I said no way! But sure enough, it smells 'chemically'. There must be some banana odor one can put in there
Oh and by the way, my daughter figured out that the name had banana in it because it's yellow, but where did the "gas" come from? (Sorry, I'm sure the answer is out there but I'm lazy to search ....)
Lois thinks it stinks tooOriginally Posted by ofioliti
Yeah, after I picked up my BG from Lotsie, my daughter wanted to smell it ans she said it stinks
Quote:
Day 1: Swirl on the entire MINI
Day 2: Amigo on the entire MINI
Day 3: Epic on the entire MINI
Day 5: BG on the entire MINI (skip a day, more cure time)
That way, you don't have to keep switching products and pads on your buffer.
Just a thought. I'll be interested to hear your take on why you prefer your method.
Here is why I do it my way, doing a section completely.Originally Posted by CR&PW&JB
Hey, Mark... I'm with you on breaking the major detailing job down into several days. But instead of working each area completely, don't you think it would be easier this way:Day 1: Swirl on the entire MINI
First, I always clay first, so one more day added. Both our MINIs are DDs, so they would be exposed to the elements between applications of different products, and except for the wax coat non of them offer any protection. Plus if they do get something on them, it may mean going back a step or more, at least another wash, which I don't feel is the best thing to be doing between applications of these products.
When I work this way, I keep my pads in zip-lock bags, so they are ready to go the next day, or even 2 days later, should something come up that prevents being able to work the next day.
Another reason I do it this way, is because not all areas need the same treatment, the boot needs it all, the roof not so much, plus this way I can spread out some of the more tedious, to me, tasks, by doing a little at a time.
Hope this makes sense
Mark
Oh, I forgot. Now I'm not 100% sure, but I think the "cure" time on BG is minutes, not hours. But I do plan on seeing what it is like if left for many hours before buffing off.
Sorry, reread your post, you meant to wait for the Epic to cure. I do plan on doing that
Mark
Mark
I knew you'd have a logical reason, Mark.
I leave mine in the garage while I'm doing my four day detailing. But yeah, if I wasn't able to do that, your method would be wise.
We need a 3rd MINI, then we could rotate one out for detailingOriginally Posted by CR&PW&JB
I knew you'd have a logical reason, Mark. I leave mine in the garage while I'm doing my four day detailing. But yeah, if I wasn't able to do that, your method would be wise.
Mark
Quote:
Mark
NOW you're talking, Mark !! Originally Posted by lotsie
Mark
Even though I got off work early today, no BGing as it's just to hot out, not for the BG, but for me. Early mornings now are may plan this weekend.
I have been playing with BG on the arches and other plastic parts. I did this mostly to see if it would leave white marks. So far, after a few days of it being on there, no white marks
. So I'm thinking it will make a good dressing, you can just wipe it on/off while doing the paint, or even in between applications on the paint, and no need to worry about getting some on the paint.
If this works over the long term, I'll still use Black Wow to remove any Epic type of product, or restoring neglected trim.
Looks like this;
Mark
Looks like this;
Mark
lotsie- that looks fantastic! BG on arches is my kinda style.
i
like that semi-gloss finish. thanks for posting it up!
so if anyone's interested...
FS: BW 90% left $250 shipped. anyone want mine?
ilike that semi-gloss finish. thanks for posting it up!
I still see a use for BW. Like on the leading edges of my rear arches they are abraded from road crap, BG did nothing to get rid of the Grey/white/worn look, Black Wow does.
Mark
Mark
Quote:
Mark
Yeah, that aggravates me to no end, Mark, that rough, somewhat chewed up area on the trip due to the road debris hitting it. Originally Posted by lotsie
I still see a use for BW. Like on the leading edges of my rear arches they are abraded from road crap, BG did nothing to get rid of the Grey/white/worn look, Black Wow does.Mark
I'm hoping the mudflaps I put on a couple months ago alleviate some of that. Yes, BW will hide that better than anything else I've tried.
I put front mud flaps on mine a week after I got him, the leading edges of the rear arches are not within their protective flap zoneOriginally Posted by CR&PW&JB
Mark
Blech... not what I wanted to hear, Mark.
Since I went two years without flaps, my rough area of trim is a little larger: The leading edge of the rear wheel trim like you say, and about the last foot or so of the side trim, right in front of that wheel trim.
On my next MINI, I want to get the JCW Aero Kit, with the painted side trim. How in the world do you keep that from getting dinged up ??
Sounds like what I have on my MINI, same areas. Painted Aero kit, I'd cover those area with clearbra material.
The mud flaps do help with road crap flying up on the doors and side panels
Mark
.Mark
Yep, I think clearbra is about the only way to go with the painted trim.
I have noticed a little less crap on the doors when the roads are wet. So the flaps are at least somewhat functional. And I do like the looks of those front flaps, too.
Just received my order of Banana Gloss yesterday. WOW.. it sure stinks!
Glad to see someone else here thinks so! Thought it would smell as good as Hydro or Slick; but since it contains mineral spirits and petroleum naptha, perhaps that is not a possibility. Well, maybe their next batch might be "new and improved" with a better fragrance.
Quote:
Literally, not figuratively. Originally Posted by MCS06
Yeah, it's the oddball of the lot.
Here's my Banana Gloss testimonial.
First, pic of my CR Cooper:
Wait...
that's not my CR Cooper. That's my JB MCSC with the CR Cooper's reflection.
Here's another:
Antoher pic of the JB MCSC. How do you like my flower bed ??
Nice, deep shine !
The darker the color, the more reflection. But in the CR you can also see how deep that shine is. And BTW, for those who always want to see the clearbra line, here's a good example:
And just a couple more shots of both of them together:
Wait...
Here's another:
Nice, deep shine !
Nooooooooooooooooooooooooooooooo... no hazing.
That stuff really is easy to work with. It's very thin out of the bottle. Goes on evenly and thin. You don't have to worry about the trim. I didn't even tape. Easy off... used one starfish mitt for each MINI. Took less than 15 minutes to take off the wax.
