Help
Old Jun 12, 2007 | 05:31 PM
glangford's Avatar
glangford
Help
My wife came home in our Accord today, with some kind of splatter on the car. (Thankfully she doesn't drive my mini!!) I immediately drove it through a touch free car wash to clean it off. Seems to be something other than mud. After washing off it seems to still leave a stain that although not directly visible when looking straight on, still leaves a visible spot when looking in light at a certain direction. I tried one spot, Wax didn't remove it, rubbing compound did, but that seems to be gently scratch the metallic clear coat surface. Any suggestions? Clay Bar? Liquid clay bar (new turtle wax product) Are these products good for a clear coat finish? I don't know what the substance was, but it was semi solid, washed off well. Industrial splatter from a truck, chicken sh** (we live in a rural area)?? Who knows
Any ideas greatly appreciated.
Old Jun 12, 2007 | 05:38 PM
MLPearson79's Avatar
MLPearson79
I would try regular clay (the liquid clay bar is nothing like real clay, do a search here to learn more about it) and see if that removes it. If not, you might be in order for Scratch-X or something similar, but I'm guessing that if rubbing compound took it of, several passes of clay (it might take a while, but it's safe for your point) should do it.
Let us know how it goes.
Old Jun 12, 2007 | 09:10 PM
OctaneGuy's Avatar
OctaneGuy
Why are you using rubbing compound???? You ought to throw that away immediately! Especially with your question that using rubbing compound seems to be "scratching the clear coat". Of course it is! It's too abrasive! You shouldn't be using anything like that if you aren't familiar enough with how to use it. You're likely to do far more damage to your paint that way.
I agree with ML--get some clay bar and see if that removes the contamination--it might take some work--clay removes particles in very small increments--and sometimes a few passes may look like it's not working--but 50 or 100 passes will! Make sure to read the directions--use clay lube or a quick detailer, and definitely ask for help if you aren't sure about how to go about doing this.
Richard
Old Jun 12, 2007 | 09:11 PM
kenchan's Avatar
kenchan
^+1 on the clay.
also, what kind of pad did you use when you did the compound? if
some cheap cotton towels or an old t-shirt they tend to swirl the finish.
plus some compounds are very coarse.
if the clay does not work, i recommend using ScratchX on a cotton pad
and use some elbow grease.
Old Jun 13, 2007 | 04:19 AM
glangford's Avatar
glangford
Thanks for the advice. I only tried a tiny spot with rubbing compound to see if the affected areas would come off, or if the area was perhaps a chemical etching or staining of the paint. It does come off, so I'll try the clay this weekend, hopefully that will do the trick.
Old Jun 13, 2007 | 06:24 AM
ImagoX's Avatar
ImagoX
Just use plenty of detail spray or soapy water as a clay lube and it should take off whatever it is, assuming that it's something on top of the clear coat and not an actual color stain or something etched down into the surface of the top coat.
Let us now how it comes out for you and good luck!
Old Jun 26, 2007 | 04:15 AM
glangford's Avatar
glangford
I used a meguair's NXT generation tech wax. That worked also seemed to remove some light swirl marks I had. A friend suggested that as a less drastic step prior to using the clay bar. Not sure if it actually removed the swirls, or just fills them in.
It was about 98 degrees so I thought I'd save the clay bar treatment for this fall when it is a little cooler. I think it still needs it.
Old Jun 26, 2007 | 07:34 AM
OctaneGuy's Avatar
OctaneGuy
I don't mean to sound mean, but you need a new friend or someone that's a bit more knowledgeable.
How is a synthetic polymer wax less drastic than clay bar????????
That like saying, eat an apple because oranges are good for you---wth?? That makes no sense.
NXT Tech Wax does contain some mild cleaners in it, and it works ok with a PC for helping to remove light swirls and for waxing, but using it by hand isn't going to remove anything. Like any good wax, it will mask some defects by filling them in.
re: 98 degrees
As long as your surface temperature is cool to the touch, you can still clay the paint---it's when it's 115 degrees or higher in the shade that you don't want to be working because nothing is cool--been there, done that.
Richard
Old Jun 26, 2007 | 10:53 AM
kenchan's Avatar
kenchan
OG - you're going to get heat stroke!
Old Jun 26, 2007 | 10:58 AM
OctaneGuy's Avatar
OctaneGuy
Yeah I once scheduled a Black NSX on one of the hottest days in Orange County last year--it was 115 in the shade. Putting M80 on the paint (working in the customers garage) just evaporated, made buffing impossible.--not to mention I was sweating buckets.
Then it got really humid and rained, and kept the wax from drying...lol.
Old Jun 26, 2007 | 11:02 AM
kenchan's Avatar
kenchan
damn... dont want to read about OG flame out, so hopefully you
got an air controlled workshop now?! i know socal's scorching sun...
it's like getting hit by needles.
Last edited by kenchan; Jun 26, 2007 at 01:31 PM. Reason: grammar. apparently i can not type while listening to people talking...
Old Jun 28, 2007 | 05:17 AM
glangford's Avatar
glangford
re: 98 degrees
Richard
Really agree with everything you said. I was just trying to remove the potential stains that my wife got on the car. That worked, was less time consuming, and less painful. Agree, I probably just filled in swirls, I think I said that. The clay bar is for this fall. Car looks fine for now.
Old Jun 28, 2007 | 05:38 AM
kenchan's Avatar
kenchan
crap, i just remembered i forgot to remove bird crap from my legacy last night... thanks for reminding..
