Possible MoS warranty shopping list
I'm interested in opinions. If I can get Dec 16th free, I'll likely go to the MoS DCMM breakfast and bring a bunch of stuff from Wegman's. If I go to the breakfast, I think I'll also set up an appointment for service. I have three issues. One is a no-brainer, but I'm not sure how to pursue the other two.
1) Groaning LSD. Do I need to know the TSB number? They will know what I mean, right?
2) Cold stumble. I didn't think I had this problem. Maybe I don't. I know that on Wednesday, I pulled out of my uphill parallel parking spot, went twenty feet and then, the engine just lost power completely. It almost stalled, but then chugged back to life and it was fine the rest of the way to work. I don't want a software update unless it's really necessary. I have a nice burble and I don't want to lose it.
3) Pirelli euphorias losing air. I have to add 5-10psi twice a week in cold weather. I confirmed today at Merchant's tire that the tires are leaking at the beads. They wouldn't unmount and seal the beads for me because they said: a) tires that new shouldn't leak, warranty should cover them and b) their machine would likely slice the sidewalls when unmounting. I know that I should ditch the run flats. I have every intention of ditching the run flats. I'd love to ditch the run flats. But if I get new tires that's all I'll be getting from Santa this year.
Also, it really offends my sensibilities to throw away tires with only 3k miles on them. I should be able to wear them down before replacing them. Does anybody think it's acceptable to have to add air twice a week to the tires of a brand new car? The BMW drivers with run flats don't think it's acceptable, do they?
So, that's where I stand. I'm also hoping that if my car is in for service while I'm chatting at the DCMM breakfast, I can hear some of your input and opinions in person. I just hope I can get that day free.
Also, it really offends my sensibilities to throw away tires with only 3k miles on them. I should be able to wear them down before replacing them. Does anybody think it's acceptable to have to add air twice a week to the tires of a brand new car? The BMW drivers with run flats don't think it's acceptable, do they?So, that's where I stand. I'm also hoping that if my car is in for service while I'm chatting at the DCMM breakfast, I can hear some of your input and opinions in person. I just hope I can get that day free.
Last edited by Revwillie; Dec 8, 2006 at 01:15 PM. Reason: address why I didn't get beads sealed.
Consider that if this sort of thing happened with non-runflats... you'd be in a lot worse situation. Runflats do have their benefits.
Again, Saturday appointments tend to be limited in scope (compared to weekday appointments), so I would check with the SA thoroughly on what they can do then, before you show up.
But it sounds to me like you have a leak, so they may need to be patched... but if it's happening to all 4 at the same time, that does seem too coincidental. I would think that one way or another, this is a warranty issue. Keep in mind though that colder air will lower the pressure, and temps have been dropping lately! Still, 5-10 psi per week is excessive.
You need to have them put a sealant on the lips of the wheel/on the tire so than the bead of the tire has a nice air tight fit. I had to get that done on one of our Winter tires just recently. Edge, make sure and check your tire pressure soon.
My run flats also gave similar problems. The front pair would always loose pressure in exactly the manner you describe. I lived with the problem till the tyres wore. The replacements don't give any problems whatsoever.
I am thinking of replacing the new run-flats for different non-runflats although I am loth as you suggest to was money on quite new tyres.
It looks like you've found the leaks - and that they're along the bead. nevertheless, one often overlooked item is to tighten the valve stems. I have the little tool for it, very simple to do.
I also think I have the groaning LSD, maybe I should get that TSB done. I hope I'm not causing any damage by continuing with the original (obviously incorrect) fluid. Edge - how long did that take for MoS to fix?
I don't remember, exactly... I had my car in for a number of things at the same time, and I know they had my car for more than a day...
I spoke to Mike Arata at the MoS breakfast and he said I should try to reach Mike Creason about an appointment this week. I emailed Mike C yesterday and got no response.
I called just now and they said they could look at it Friday but tires are "never covered under warranty". I also can't get a loaner since I didn't buy the car from Sterling. If I want to try to have them fixed or replaced under the tire warranty from the manufacturer, I have to go to the dealership from which I bought the car (Towson, the only place in the area that had a checkmate in inventory).
On Christmas eve, I need to drive 300 miles round trip to get my Dad and bring him to our house and it looks like I'll have to take Friday off from work if I have a snowball's chance of having the issue fixed in time.
If it is deffinately a not sealed bead, than take it to any tire place. I would recommend going to Tirerack and find an installation place. If you have RFs, it should be like $45 to take off and $45 to put on. That is about the average and shouldn't be much more than an hour.
I have an appointment for Friday morning in Towson, but the SA there is already convinced that I have bent wheels. He says he has never heard of the run flats leaking from the beads, ever. Thanks for the Tire Rack idea. I'll make some phone calls tomorrow.
Hope this helps. Just be prepared for the dealer to want/need to independently troubleshoot and determine that your groaning LSD is the groaning LSD problem in the TSB that you tell them about (which they won't search for and read when you tell them about it).
BTW, I too received no response to the online booking attempt. I was told by the SA when I checked in that I should've called in the first place, because that's the way to get things done - by the phone. Seriously? So I wouldn't use their online booking for some time to come.
Any chance your DSC/ASC kicked in and chopped the power to the engine? Sounds like what happened to me a time or two when I first got my MINI and didn't have a feel for how much ummph I could give it without breaking traction. Plus, if it was cold (both the road surface and runflat tires) perhaps that contributed?
After that lesson and reading more on NAM, when I needed a repair, I went to Craven's Goodyear on Columbia Pike (near Rt 7, in Bailey's Crossroads). Awesome service, knew exactly how to handle runflats, repaired it and remounted - out for under $30. Everything's been great since.
The dealer (MoS anyway) will insist that your tires need to be replaced - they don't repair runflats and tell you they can't be repaired. On my wife's car, that cost us >$200. After that lesson and reading more on NAM, when I needed a repair, I went to Craven's Goodyear on Columbia Pike (near Rt 7, in Bailey's Crossroads). Awesome service, knew exactly how to handle runflats, repaired it and remounted - out for under $30. Everything's been great since.
No leak was detected on the one wheel. No surprise. When temps are above 40, it doesn't leak at all. The other wheel leaked from the bead. They unmounted the tire and found the cause: Drumroll please.....
The manufacturer's (Pirelli) paper sticker was left on the bead of the tire.
They peeled that thing off, cleaned the bead, applied sealant and remounted. No leaks detected afterwards.So, in this case, I'm paying about $30 to fix a problem that can be traced back to Oxford. (assuming they mount the tires there) I think I'm OK with that. I've blown $30 on much stupider mistakes made by me and others.
If I lived closer to Towson or Sterling, I would have been more insistent that they diagnose the problem and I would have went nuts if they tried to bill me for sticker removal. In this case, I got off somewhat cheap, but I still want to make a point at MoS or MoT. I want some vindication or closure of some kind. I want a friggin cookie or something.
OK, get this. I had to go to Craven's on Lee Hwy because the runflat specialist at Columbia Pike is out today. No biggie. Long Metro ride to King Street.
Ask and you shall receive.
Aug 21, 2015 11:25 AM
