DC Metro MINIs (Archive) The old DC Metro MINIs club forum, now closed. Visit their new forums at www.dcmetrominis.org/forums
Help Me??
Old Jan 24, 2008 | 11:45 PM
ayyado's Avatar
ayyado
Help Me??
Was just wondering if Magnaflow exhaust can be installed...without welding or taking it to a shop? is it just bolt in....highly doubt....
someone want to help me install this? or which shop is highly recommended for these things??
Old Jan 25, 2008 | 05:37 AM
Maxicooper's Avatar
Maxicooper
There are several shops in the area that might be able to help.
BEHE Performance: http://www.beheperformance.com/
Mach V: http://www.fastmini.net/
Funktion Auto Group: http://funktionauto.com/index.asp
Autotechnica: http://www.automotivecoupon.com/
Or if you want to go up to Philly, Helix is also expert in MINI as well.
Helix Motorsports: http://www.helix13.com/mini/products
Old Jan 25, 2008 | 10:47 AM
drocay's Avatar
drocay
I had my buddy install the Volt for me which is exact copy of the Magnaflow atleast the original magnaflow and it was perfect fit , no welding or anything of that sort.
Old Jan 25, 2008 | 11:06 AM
mmatarella's Avatar
mmatarella
They are normally bolt in. I plan to do mine in two months or so...
Old Jan 25, 2008 | 11:59 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
I had a Magnaflow added to my car recently. It required a bit of attention with a pry bar because the hangers were a little off. Should be relatively easy to install yourself if you can get the car sufficiently high enough off the ground to work under it comfortably.
Old Jan 27, 2008 | 08:25 AM
e30r56's Avatar
e30r56
I could help with the install. PM me.
