Cooper (non S) Modifications specific to the MINI Cooper (R50).
Busted CVT options
Old Apr 27, 2013 | 07:22 PM
  #101
Densmini's Avatar
Densmini
By the way, what got it running?
Old Apr 27, 2013 | 07:24 PM
  #102
tjrev335's Avatar
tjrev335
Jumping the wires like you said... i musnt have had the jumper in there secure so i prayed tried it again lol
and she fired right up
Old Apr 27, 2013 | 07:28 PM
  #103
Densmini's Avatar
Densmini
Good work! Now make that linkage and cables cry "Uncle!"
Old Apr 27, 2013 | 07:29 PM
  #104
tjrev335's Avatar
tjrev335
Haha i was so giddy with excitement when it started i decided to call it a day and eat some steak lol
Old May 16, 2013 | 06:20 PM
  #105
tjrev335's Avatar
tjrev335
Alright so ive got this bad boy back on the road, been driving it for a week now runs great and the only issue is an airbag light thats on, but i dont know why. So now that im fairly certain this thing is pretty solid i would like to figure out this clutch switch and hopefully get cruise to work but im missing the clutch switch in my wiring diagram....
Old May 17, 2013 | 05:39 AM
  #106
Densmini's Avatar
Densmini
TJrev, do you have a Bentley manual?
Old May 17, 2013 | 06:13 AM
  #107
tjrev335's Avatar
tjrev335
No i believe its a haynes
Old May 17, 2013 | 06:57 AM
  #108
Densmini's Avatar
Densmini
If you can lay your hands on a Bentley, you will find the writing diagram for the clutch switch therein. There may be a PDF online somewhere...links, anyone?
Because the CVT lacks some of the actual wires in that area, you will have to make a few of your own. If I recall correctly, you'll have to tap into the brake pedal switch for some of your inputs. There is one tricky bit if you want crusie control: you'll have to run a wire from the proper terminal on the EWS to the proper terminal (pin) on the DME. Neither is present in the plastic connectors on either end, so you'll have to get some dinky ones, connect your wire, and fit them. I took them from the (now unused) connector for the CVT module under the dash to the right of the steering column. Then you'll need to fish it through the firewall, etc. The EWS end of things isn't hard. The DME...well, that's a different story. Let me know when you get that far, and I'll share my (partial) success story.
Old May 17, 2013 | 07:04 PM
  #109
Densmini's Avatar
Densmini
TJ, if you go to the electrical section in this forum, you'll find a sticky with 2006 Cooper S wiring diagram. Page 38 of the PDF shows what you need to know.
Old May 17, 2013 | 07:56 PM
  #110
tjrev335's Avatar
tjrev335
alright ive got the pdf up and i printed out the wiring diagram, most of the wiring looks fairly simple, is the dme the box thats inside the battery box? also i dont see the wire going from the ews to the dme
Old May 17, 2013 | 08:00 PM
  #111
tjrev335's Avatar
tjrev335
or is i actually only the wire from terminal 2 on he clutch module that goes to the dme?
Old May 18, 2013 | 03:38 AM
  #112
Densmini's Avatar
Densmini
The DME is the ECU and it is in the batery box. Two big connectors going into it, and you will be concerned with the smaller of the two. You'll also have to make up your own wire to run from the EWS to the DME, with the tiny female connectors as mentioned in a previous post.
Old May 26, 2013 | 12:08 AM
  #113
minipatcher's Avatar
minipatcher
I am doing this this swap too and almost get this work finished. But I got a problem with driving axle (output shaft). I booked both sides driving axle from autozone for mini cooper S. But the the passenger side one doesn't have support bracket, so I reuse the bracket from the old one. And then I find the bracket can't be screwed into the position. I don't know it is the problem to driving axle or bracket. I need to finish this work in this week. Now the best way is to book the driving axle with bracket from website, please give me suggestions to get the right one. Thanks
Old May 26, 2013 | 09:07 AM
  #114
gknorr's Avatar
gknorr
A site like penske parts can help you sort out issues like this by comparing the part numbers of the S to the non-S. Take a look there and see if you can find the part you're wondering about.
Old May 26, 2013 | 01:32 PM
  #115
Densmini's Avatar
Densmini
Are you sure you have the bracket in the right position? In other words, could you have it flipped "upside down" or not driven along the shaft enough? I don't remember encountering this problem,sorry.
Old May 26, 2013 | 05:36 PM
  #116
minipatcher
After some research, I think it is bracket problem, because the new axle has 34 splines at transmission end which only can fit into 6MT transmission. The old bracket from CVT can't be used for 6MT transmission. Since there is no part number for bracket, I can't confirm this. But the bracket for 5MT and 6MT is same, that caused my mistake to reuse the old one from CVT. Now I need to order a axle assembly from some website. Hope this time everything will be OK. By the way, the bracket can only be installed in one way and can't be upside down. Thanks a lot for your suggestion.
Old May 31, 2013 | 01:31 PM
  #117
Densmini's Avatar
Densmini
Here is my attempt at writing up the connection needed to enable cruise control after swapping a manual trans into your ex-CVT. Comments and suggestions for improvement welcome:
After you have had someone reprogram your DME from CVT to manual, you will need a clutch signal from pin 2 on the Clutch Switch to pin 85 on the DME (Wiring diagram pin 4 in the Bentley).
Although it is not the focus of this write-up, naturally you will need to fit a clutch switch and wire it up.
Tools: some very small screwdrivers, soldering stuff, wire stripping tool, a tweezers or thin needle-nose pliers, good flashlight and I STRONGLY recommend some kind of magnification for the fine work.
Parts: 22 ga. Wire, and 2 tiny female connectors (TFC), some zip-ties.
1) If you are careful you can remove as many TFC as you need from the now unemployed CVT module under the dash to the right of the steering column. The module’s "plug" is blue and is full of TFCs. Pick a wire color you like, cut the wire leaving a couple inches to work with. Use a tiny screwdriver to depress the retaining spring on the TFC and slide it out of the plug in the direction of the wire.
2) Run your choice of wire through your choice of hole in the firewall. Once through, make sure you have enough length to run from the EWS to the DME with a bit to spare, then zip-tie it to the harness running to the DME.
3) Disconnect the battery. Wait a couple of minutes. Remove the smaller of the two big plugs going into the DME. Got your magnifying glass? Good. Next is the fiddly part:
4) That big ol’ plug has a black plastic cap that is secured to the harness by a zip tie. Cut the zip tie and lift up on that end of the plug until it pops free (it’s also held in by a couple of tabs that go into slots at the other end and two more tab-and slot deals on each side). You will see a bunch of wires all crowded into a small space. All those little wires disappear through a rectangular grey plastic piece full of holes. Take note of the wires at the front left corner. Starting from the front and working toward the rear of the car, on the leftmost row of wires, there should be a wire in the first hole and the second hole, but none in the next two holes. The 4th hole is your goal because it corresponds to pin 85.
Now have a look into the socket on the DME you just pulled that plug from. You will see a very small 82 in the lower left corner in the base of that socket. That means pin 82. The pin to right is 83, and so on. Pin 85 is the clutch input signal and that is the one you are concerned with.
So to recap, your ambition is to put a tiny female connector inside the big plug that lines up with pin 85.
5) Here’s how you do that and it will require patience: That grey plastic piece you noticed earlier? It can be carefully levered upward using a small screwdriver. A spritz of silicone lube on the wires helps. It is about ½ inch or so thick, so it will keep sliding up for a while. Take your time, working all around each edge in turn. On some there are little tabs on the sides that serve as mild retaining clips- I broke mine (clumsy) with no ill effects. Your goal is to get it at least ¾ of an inch above the hole it came out of, so you can work under it. This may require gently “untwisting” the maze of wires running into the connector to straighten them a little and ease the grey piece’s journey.
Underneath it is an orange rubber water seal. You can carefully slide this up, too.
Now you should be able to look down into the 4th hole/pin 85. Starting from below the orange seal, push the wire on the TFC you clipped earlier through the 4th hole in the orange seal up through the 4th hole in the grey piece.
6) Moving to the underside of the big plug, you will notice another orange rubber water seal and just below it there should be a blue plastic bit on each end of the big plug. Don’t concern yourself with the one on the end with the bigger terminals.
Using your itty-bitty screwdriver again, you can gently lever that blue plastic piece until it slides out. It’s about an inch long, and it serves to lock all those many TFCs in place, so don’t get muscular here. A delicate touch is called for; you don’t want any other TFCs popping out (ask me how I know this), you just want to pop one in! The TFCs are also retained by their little springs in the black base but there’s no sense taking chances.
7) Slide the blue piece out and prepare to insert your new TFC into slot 4/pin 85. If you have a tweezers or a thin needle nose pliers and magnification it helps with this step. Slide the TFC into the pin 85 slot in the black base. When you do, make sure the little retaining spring is facing the outside of the big connector so it clicks into place. Using a flashlight and some magnification, you’ll see the way the rest of the pins are oriented and you can match them. You should also triple check you have the right hole! (You should only have two to choose from). Once it’s in place, slide the blue plastic bit back in. Gently push the orange water seal back into the big plug, and the grey piece back on top of that.
IF you realize with horror that you just clicked into the wrong slot, don’t panic. On the bottom (DME side) of that big plug there are VERY small slots next to the pin openings. Slide something like a welding tip cleaner or straight pin into that little slot until the TFC lets go. Tug it out by the wire and reposition it.
8) Solder the bit of wire with the TFC to the wire you ran through the firewall- come on, splash out on some nice heat shrink tubing!
9) Replace the black plastic cover over that bundle of wires- you may have to re-twist them to get them all to fit- and secure it with a zip-tie.
10) Replace the big plug into the DME and move to the Clutch switch. The other end of your new wire goes to terminal 2 on the wire coming out of that switch. Now you will need to do a similar but less complicated version of the procedure you just finished with wire on the switch that corresponds to pin 4 (on the switch). You must fit a TFC into the plug that goes into the EWS. Pull the plug out and confirm the hole for pin 8 on the EWS.
The EWS has its pins numbered just like the DME: using a magnifier and a flashlight, you’ll see the numbers next to the pins: the two big ones are 1 & 2, then a slightly smaller one, 3, and then a batch of tiny ones. Count to number 8: your pin. Look at the plug and you’ll figure out how your new little female connector goes in.
Solder that bad boy to the other end of the wire to your clutch switch (which is, we assume, otherwise correctly hooked up), reconnect your battery and go for a drive, enjoying the smooth ease of cruise control once again.
Last edited by Densmini; Jun 19, 2013 at 05:49 PM. Reason: I made two errors: confusing the EWS and Clutch Switch connections and pin numbers. .
Old May 31, 2013 | 06:25 PM
  #118
gknorr's Avatar
gknorr
Wow - well done. My hats off to you for sticking with it. So cruise control just automatically started working once everything was wired in?
Might just have to give this a try over the summer...
Old May 31, 2013 | 07:26 PM
  #119
Densmini's Avatar
Densmini
Yup, no fuss no drama. Worked like a charm.
Old May 31, 2013 | 07:41 PM
  #120
gknorr's Avatar
gknorr
Definitely challenged to try it this summer on mine.
Old Jun 19, 2013 | 09:29 AM
  #121
gknorr's Avatar
gknorr
After you have had someone reprogram your DME from CVT to manual, you will need a clutch signal from pin 4 on the EWS to pin 85 on the DME.
Looking into to doing this soon - I have the clutch switch. What did you do about the connector for it? What did you do about wiring it in?
Looking at the wiring diagrams (link below), it looks like additional wires will need to be snapped into the DME and EWS. Did you do this as well?
https://www.northamericanmotoring.co...tch_wiring.pdf
Old Jun 19, 2013 | 10:02 AM
  #122
Densmini's Avatar
Densmini
As per the write-up above, I did put new connectors into the EWS and DME and a wire between them, and a connector and wire between EWS and clutch switch. I got the connector for the clutch switch when I ordered the clutch switch from someone parting out their MINI. I asked pretty please and they threw in the harness for free. Then I just used the wiring diagram to find out where to tap those wires into the loom near the brake pedal switch.
Old Jun 19, 2013 | 10:34 AM
  #123
gknorr's Avatar
gknorr
Gotcha - so I'll basically have to source that clutch switch connector. From what I can tell, this BMW part should work:
http://www.eeuroparts.com/Parts/2853...s-61116911072/
Based on what I'm reading in the write-up, you basically connected EWS pin 4 to DME pin 85.
Wiring the clutch switch (not in your write-up) in would involve the following connections if I'm not mistaken:
pin 1 to ground
pin 2 to DME pin 4
pin 3 to Connector X10200 pin 3 (not sure what this connector is)
pin 4 to EWS pin 8
Did you previously wire these in as well?
Old Jun 19, 2013 | 11:03 AM
  #124
Densmini's Avatar
Densmini
Gknorr,
That harness looks like it will do the trick. I'll have to climb under my dash this evening and see if those connections are correct...mine came with clipped-off wires so I had to solder my connections in. I'll try to verify all pins and connections.
Old Jun 19, 2013 | 11:10 AM
  #125
gknorr's Avatar
gknorr
Gknorr,
Sounds good - thanks!
