Cooper (non S) Modifications specific to the MINI Cooper (R56).
Compact air horn
Old Aug 12, 2010 | 07:17 AM
MsEmily's Avatar
MsEmily
Compact air horn
Looking for someone that has recently added a compact air horn to their love. Would like to keep the original horn, but add the air horn for those that seem oblivious to Kit. I noticed Moss Mini carries one that is reasonably priced. Question ease of installation.
Old Sep 15, 2010 | 11:44 AM
DixonL2's Avatar
DixonL2
They're not too bad to install. I put one on my R53, the only real issue was finding a good location - and that can be a challenge. THink about the "having two horns" thing, though - if you've got the OE horn, then you need completely separate wiring and a switch for the extra horn, as well as (in an emergency situation) the presence of mind to honk the OE horn, notice that the offending driver doesn't hear you, then toggle the aftermarket horn...
Easier to use the OE horn wiring to trip a relay, running 12v+ power to the aftermarket horn, and be done with it.
I just put $35 WOLO horns on my wife's Kia Soul, MUCH MUCH louder than stock, and a pretty straightforward install. Sounds good, too, kind of a "deeper Ferrari" sound.
Old Sep 16, 2010 | 11:49 AM
Neufusion's Avatar
Neufusion
I can't recall the brand, but I have a mini air compressor and two air horns. The air compressor sits in the little box area under the top vents on the hood and the horns mount with a bracket.
I opted to replace the OEM horns with the air horns, so I just disconnected the two OEM horns and then ran the power line for the air compressor right into the original wiring harness at the horn.
The sounds is huge! Sometimes people have to do a double take because they hear a big *** horn and only see little MINI. =]
Old Sep 16, 2010 | 11:53 AM
Neufusion's Avatar
Neufusion
Why do you want to keep the original?
If I don't want to blow someone away, I can just quickly tap the horn and it lets out a softer sound since the compressor doesn't spin up all the way.
It would be funny to have both hooked up to the same switch. If you held your horn down, they'd know you are really pissed! =]
one73ronin
23
Sep 22, 2015 09:56 AM
Tires, Wheels & Brakes
Sep 10, 2015 02:53 PM
Sep 10, 2015 11:55 AM
