Cooper (non S) Modifications specific to the MINI Cooper (R56).
Simple performance upgrades
Old May 13, 2010 | 06:25 AM
  #26
drewstermalloy's Avatar
drewstermalloy
Originally Posted by justacooperjay
anybody done the Torque Arm Insert upgrade on their own? sounds like a good deal to me, just didn't see a how to on it. Would love to do both the torque arm and lower engine mount as well.
I've been wanting to get that too.
Old May 28, 2010 | 07:21 PM
  #27
Reed's Avatar
Reed
Cheap Mod
How about a Sprint Booster, Relitivly Cheap but Nice Mod For About $300.
Old Jun 16, 2010 | 05:49 AM
  #28
jbewley's Avatar
jbewley
I did the torque arm bushing last week and it was a real improvement. Shifting is smoother as well a power transfer. It does give you a bit of vibriation in the car at idle, but a small trade off. I was told not to do the lower bushing too, as the vibriation would be even more noticeable. I would not want any more then the torque arm bushing give me.
Jim
Old Jun 16, 2010 | 09:46 AM
  #29
Grendl's Avatar
Grendl
Jim
Can what the install entailed Jim? I'm just 2 weeks into my Mini and haven't even cracked the hood yet.
Old Jun 16, 2010 | 10:10 AM
  #30
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Glad you like it. The NM torque arm bushing is pretty much the first mod we do to every R56. It's cheap and you actually see the benefit after installing.
Old Jun 16, 2010 | 10:17 AM
  #31
ChineeBoy's Avatar
ChineeBoy
Jim
Hey Jim,
How hard is it to change the torque arm? Looking to do my first mod on my 5 day old mini
cheers!
Old Jun 16, 2010 | 12:13 PM
  #32
jbewley's Avatar
jbewley
Originally Posted by ChineeBoy
Hey Jim,
cheers!
Just take out two bolts and remove the torque arm. You don't replace anything, but merely insert the two bushings and replace the torque arm. Nothing to it. A lift helps, but two jack stands will work just fine. 15 minutes tops.
Jim
Old Jun 16, 2010 | 12:14 PM
  #33
jbewley's Avatar
jbewley
Thanks for your advice on this Way. Now I'll need to get you to install the Craven Short Shifter at next years Dragon.
Jim
Old Jun 16, 2010 | 01:22 PM
  #34
Grendl's Avatar
Grendl
Is the same true for a standard R55, or are the results diminished?
Old Jun 16, 2010 | 01:34 PM
  #35
jbewley's Avatar
jbewley
Way, do you recommend the Sprint Booster now, as the throtte delay is much more noticable when rev matching on the down shift?
Jim
Old Jun 17, 2010 | 03:23 PM
  #36
jbewley's Avatar
jbewley
Ordered the Sprint Booster from WMW an hour a go and it is already on its way.
Jim
Old Jun 23, 2010 | 05:18 AM
  #37
jbewley's Avatar
jbewley
Installed the Sprint Booster yesterday and it took all of 10 minutes. Hardest part was deciding where to mount the switch.
For the justa I find it amazing and is the perfect fit with the torque bushings. The throttle is more like direct linkage and I Like being able to move the throttle just a little and getting a responce right away, rather then having to mash the throttle. Since a tune is not in the cards for us, this is a good deal. I am very happy with it.
Jim
Old Jun 24, 2010 | 06:36 PM
  #38
rjtrout2000's Avatar
rjtrout2000
Sprint booster sounds like it would be worth the coin. The 30 day trial may be the determining factor!
Old Jun 24, 2010 | 10:48 PM
  #39
JJUK's Avatar
JJUK
Jim
Good to hear, I'm tempted now!
Where did you end up mounting the switch?
Old Jun 25, 2010 | 04:24 AM
  #40
jbewley's Avatar
jbewley
After several days I have found that the torque arm bushings and he SB are the "justa tune". I use the race setting all the time now and find that low end responce is fantastic. I love this set up.
Easy location is on the right side of the foot well, up near the fan control ****. Easy to hide the cord, see and reach.
Jim
Old Jun 25, 2010 | 09:02 PM
  #41
WayMotorWorks
Vendor
That is great, I keep saying that Torque arm insert is huge bang for the buck even on a Justa Cooper.
And the Sprint Booster can be a big help with the throttle delay.
Old Jul 3, 2010 | 02:24 PM
  #42
jbewley's Avatar
jbewley
After having the SB in the car for a week, I can't see how I got along with out it. Yesterday I gave it a good long run in race mode, with the Sport Button on too. All I can say is it felt like the Energizer Bunny. I highly recommend this and the torque arm bushing for the justa.
Jim
Old Jul 3, 2010 | 04:56 PM
  #43
grueinthebox's Avatar
grueinthebox
Potentially stupid question, but you'll have to forgive me as this is the first FWD car I've owned in 15 years and the only one I've ever had any interest in doing any mods to... Is there any reason the torque arm couldn't be removed and replaced with the car on ramps? I.E. with the front wheels attached to the engine/transaxle, will the weight of the car cause the drivetrain to shift once the torque arm is unbolted, preventing it from being replaced?
Jacking is a pain in the rear compared to just pulling the car up on my Rhino ramps... Call me lazy, but I like to avoid it when I can.
Old Jul 3, 2010 | 07:33 PM
  #44
jbewley's Avatar
jbewley
That will work fine. You just want to be sure it won't fall on you.
Jim
Old Jul 4, 2010 | 12:03 AM
  #45
JeffreyC's Avatar
JeffreyC
Way,
I have a R56 with the BSH lower mount with street bushings. I'm not thrilled with the amount of vibration coming thru to the cabin. Does this get better with time (I have about 200 miles on the mount) and / or would the NM TA bushing be a good alternative?
Thx!
Old Jul 4, 2010 | 07:19 AM
  #46
grueinthebox
Installed the NM bushings this morning, and all I can say is "wow"... Should have been this way from the factory. I find the increase in NVH to be noticeable (although I was looking for it), but not significant, IMO. Shifting is hugely improved as is the pick up. Makes it really easy to drop the hammer and whip through the gears. Fun factor x10.
Had it done in less than 10 minutes, including a little fumbling to get the rear bolt started (added about 45 seconds to the time). Didn't even bother removing the front bolt - loosened it, removed rear, rotated the arm down, stuck in the inserts and put it back together. Thanks for the affirmation on the use of ramps, Jim.
Kudos to Way and the crew, btw - I ordered Thursday late afternoon, got a call about 30 minutes later confirming my year/model, package went out Friday morning and got here yesterday.
Old Jul 5, 2010 | 01:38 PM
  #47
WayMotorWorks
Vendor
Originally Posted by JeffreyC
Way,
Thx!
Honestly the NM bushing would be alot less vibration for you. If you put 200 miles on your current setup it's not going to get better.
Old Jul 5, 2010 | 02:42 PM
  #48
jbewley's Avatar
jbewley
Now, add the Sprint Booster and you will never look back, except to see if the "S" is still behind you.
Jim
Dec 5, 2016 06:31 PM
Zettinger
Aug 25, 2015 04:04 PM
Aug 21, 2015 11:18 AM
Aug 21, 2015 10:41 AM
Aug 11, 2015 09:01 AM
