Cooper (non S) Modifications specific to the MINI Cooper (R50).
What oil do I use for the transmission?
Old Apr 22, 2008 | 11:26 AM
seigmann's Avatar
seigmann
I need to know what kind of oil I should use for my Midland transmission. I have a 2003 R50 with about 76k on it. The transmission has a weird sound like squeaking rubber when I shift. And also, where should I have them change the oil? I know they do it at like Brake Masters and other places but should I have them do it?
Old Apr 22, 2008 | 08:41 PM
hemiheaded18's Avatar
hemiheaded18
It's a little bit of a pain because the drain and fill plugs are in a bad spot but it can be done in a driveway. I had mine done when my car was inspected at a local garage I trust. Also, I use (along with a lot of other people here) used RedLine's MTL. Great stuff, costs maybe $6-8 a quart. You'll need 2-3. The weight is 70W80 Manual Trans Lubricant (MTL).
Old Apr 22, 2008 | 08:54 PM
COR BLMY's Avatar
COR BLMY
I will also vote for Redline MTL.
If you can change oil you can do the trans.
The fill plug is the fill sight hole, on a level surface.
I put a tube (maybe 2 feet) on a funnel, & into the fill hole and, tape the funnel so that I can pour in the fluid. When it "overflows" out of the site it is full.
Old Apr 23, 2008 | 12:19 AM
seigmann's Avatar
seigmann
Could you guys maybe take some pictures for me?
Old Apr 23, 2008 | 12:23 AM
seigmann's Avatar
seigmann
And also where is the fill sight hole?
Old Apr 23, 2008 | 07:36 PM
AliceCooperWA's Avatar
AliceCooperWA
I'd take pictures, but I won't be changing my fluid for several months...
You should invest in a haynes or bentley manual. The ultimate DIY manuals.
Old Apr 23, 2008 | 07:44 PM
seigmann's Avatar
seigmann
I have a TIS cd
silence2-38554
Nov 12, 2015 09:39 AM
Aug 25, 2015 09:33 AM
finn
Aug 21, 2015 07:59 AM
Lex2008
Aug 16, 2015 08:33 PM
