Cooper (non S) Modifications specific to the MINI Cooper (R50).
Lightweight crank pulley on ONE/Cooper? Pls comment
Old Jul 8, 2007 | 09:40 AM
vodka's Avatar
vodka
Hi all,
I'm interested in Alta Lightened Crank Pulley for my 2004 CVT ONE. What size shd I go for, 2% or 0% (oem size)? Will it cause any problem?
I did a search abt lightweight crank pulley and most of the result is abt MCS .Any ONE/Cooper owner has it? Please comment
Thanks alot
Old Jul 9, 2007 | 11:55 AM
R50 Paul's Avatar
R50 Paul
The One/Cooper Crank pulley is almost as light as those for the MCS. There is NO benefit from this mod.
Old Jul 16, 2007 | 11:24 PM
Cubby's Avatar
Cubby
I'm sorry to disagree with R50 Paul with the weight of the crank pullies for the MC and the MCS. The MC's OEM pullie is a bit lighter and than the MCS pulley. The after market pulley for the MC (0%) is a tad bit lighter but the weight difference wouldn't make any real noticable changes. If you decide to go with a lightened crank pulley from Alta, you need to heat the pulley prior to placing it on the crank. I experienced this difficulty and decided not to bother with the lightened pully.
Old Jul 17, 2007 | 06:06 AM
cristo's Avatar
cristo
Alliance Member
The R50 MC has a non-damped pulley (weighs 3#), so not quite as much benefit
going to a lighter crank pulley as on an MCS.
The older style R53 MCS pulley has a damped pulley (weighs 7.3#).
The newer R53 MCS pulley is lighter but still damped (about 5.8#)
Also, the MC flywheel is only about 17# compared to the MCS at 27#
Old Jul 17, 2007 | 09:56 AM
R50 Paul's Avatar
R50 Paul
HAHAHA That's what I ment to say in my post!!!! So the genral consensous is do the mod if you want but you won't gain anything but a thinner wallet and another check on the mod list.
Old Jul 17, 2007 | 08:01 PM
vodka's Avatar
vodka
Got it, thanks for all the replies. This mod is off my list
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
VanisleRyan
Sep 13, 2015 09:55 PM
boydie
Sep 13, 2015 05:06 PM
M7Speed
Sep 3, 2015 07:48 AM
