Upgrading the headlights
Old Nov 21, 2006 | 05:09 PM
shorn's Avatar
shorn
I'm planning on upgrading the headlights on my '80 Mini. The std. Lucas (aka Prince of Darkness) lights are awful. Has anyone else done this? I'm concerned that the wiring may not take the current draw of the newer halogen or Xenon bulbs. Also the light switch in the stalk. Also the alternator, although my Mini appears to have an aftermarket alt. installed. Not sure whether the addition of a relay (along with heavier gauge wiring) might not be a bad idea. Thoughts anyone?
Old Nov 21, 2006 | 06:49 PM
Big Norm's Avatar
Big Norm
Philty has some kick a*s light upgrade..........Bright as could possible be......i think he got them off a BMW that he Repo'd......lol
Old Nov 21, 2006 | 10:44 PM
BFG9000's Avatar
BFG9000
If it's US-spec, there are plenty of HID conversions for 7" round headlights available because many motorcycles use them.
HID systems use 35w bulbs that draw ~42w after ballast losses: comparable to the low beams of a standard sealed beam headlamp and less than the brights.
There are also H4 conversions but those draw more power at 55/60w.
Relay kits are commonly used with older cars because the corroded old wiring cannot deliver full voltage resulting in dim lights. However even the low voltage is enough to run the relay, so the kits extend the life of the switch and delay the need to rewire everything.
Old Nov 22, 2006 | 04:21 AM
Capt_bj's Avatar
Capt_bj
My choice
http://www.minisport.com/classic-min...s-product.html
Crystal Angel Eye Headlamps
Old Nov 22, 2006 | 04:36 AM
Minimad's Avatar
Minimad
Use the relay method with your Lucas switch. It won't take it.
Old Nov 22, 2006 | 06:32 AM
shorn's Avatar
shorn
Thanks for the confirmation of the relay - a safe way to go. Presumably the gauge of the wiring itself is sufficient for Xenon or Halogen lamps? I was planning on using these, with Xenon bulbs, from GBCarparts.com
http://www.gbcarparts.com/proddetail...=Lamp7Headlamp
Old Nov 22, 2006 | 06:51 AM
joltfreak's Avatar
joltfreak
Originally Posted by Capt_bj
that's what i got but haven't put them in yet
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 10:29 AM
Ntety
Sep 2, 2015 08:39 PM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
