drum to disc brake conversion
Old May 12, 2005 | 05:31 PM
STLMINI's Avatar
STLMINI
my MKIII mini has drum brakes front and back. i'd like to convert the front to disc. does anyone have any suggestions for what i should get? my wheels are 10".
also, what should i expect to spend?
thanks in advance.
Old May 12, 2005 | 06:26 PM
8ball's Avatar
8ball
A couple (a few?) of my Mini's had the double-leading shoe drums (with 1-1/2" shoes vs. the 1-1/4" on the single leading shoe) and with good drums (like MiniFins) they would out-perform Cooper discs - not 'S' discs, but smaller Cooper discs ...
... short of getting a Cooper 'S' basket case parts car and swaping out the front suspension, there are a few types of conversion kits ... like the one shown here :
http://www.minimania.com/web/Item/MM.../InvDetail.cfm
Old May 13, 2005 | 12:25 PM
queenB's Avatar
queenB
Coordinator :: Smoky Mountain MINIs
Just for the record this is Hotelcalif on QBs login.
You would have to go with Cooper S disc. I agree with above post. Good twin leading are better than stock 7.5 disc. You could go to 12" wheels and use the 8.4 disc which are much better. The 7.5s are very pricey also.
Old May 13, 2005 | 01:03 PM
CasaMini's Avatar
CasaMini
Mini Disc Brakes
If you're comtemplating buying Cooper S 7.5" disc brakes, you might want to do some comparison shopping. I bought my complete kit from Mini Spares in England instead of Mini Mania in the USA. The differance in cost was more than enough to cover the expence of shipping and still saved a couple of hundred bucks. Don't forget to order the backing plates and the brake hoses for the disc brakes as they are not part of the kit. As the others suggested you might want to go with the 8.4" disc brakes which are cheaper and readily available but then you have the added expense of getting 12" wheels and tires.
CasaMini
patsum
26
May 29, 2021 06:29 PM
tylewis
Sep 6, 2015 07:36 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
Ntety
Sep 2, 2015 08:39 PM
