1970 morris mini redline?
Old Dec 14, 2004 | 02:41 PM
nbame786's Avatar
nbame786
hey guys...(and girls), i just bought a nice 5" tach to mount in my mini ...but i don't know what to set the redline for the shift light...it's a rhd 1970 austin-morris mini... i'm planning on doing a vtec swap in the spring, but for now i need to figure out what to set this to....anyone know? thanks, appreciated
Old Dec 14, 2004 | 02:57 PM
nbame786's Avatar
nbame786
anyone??
Old Dec 14, 2004 | 06:54 PM
Grahambo's Avatar
Grahambo
Motor size?
Old Dec 14, 2004 | 07:11 PM
nbame786's Avatar
nbame786
it's an 1100cc, tuned by john cooper works garage.... so idk what the horsepower is either?
Old Dec 14, 2004 | 08:42 PM
nbame786's Avatar
nbame786
bump....
Old Dec 14, 2004 | 11:10 PM
8ball's Avatar
8ball
REDLINE varied because of things like the timing chain ( simplex w/ tensioners means lower redline than duplex ), and valve springs (single or double) and what cam is lifting them.
The fact that it is tuned at JCW means that there may be components that the factory motors didn't get - and it may even be balanced, which will help with longevity and may give you more rev's to play with ...
... but the biggest factor is that it is a 1098; the longest stroke (relatively, proportionally) of all the A series blocks means that you shouldn't crank it up too far - i'd limit it to about 5500 or 6000.
Old Dec 15, 2004 | 03:48 AM
Pflashinaz's Avatar
Pflashinaz
I would say 6 grand tops! Especially if you don't know what's inside this motor. 22 yrs. ago I built an 1100cc for my mini. Did not spare any expense, tufftrided the crank, shot peened the rods lightened everything including the flywheel and balanced it and it was safe for the occasional slip to 8 grand but certainly not on a daily basis. Best to stay safe with this one.
Old Dec 15, 2004 | 06:51 AM
Rick-Anderson's Avatar
Rick-Anderson
The 1100 is a long stroke and relatively low reving engine compared to most other A-Series units. It is actually one of my favorite engines due to the gobs of torque on tap. Although it may be OK to rev a little higher, I wouldn't push it beyond 5,000.
Why the concern? Is it reving super high at freeway speeds? Was the engine taken out of an MG1100? If so - and the Mini is running 10" tires instead of the 12" (MG size) - you might want to consider changing the final drive or contacting Mini City to see if they have the Jack Knight "overdrive kit."
Old Dec 15, 2004 | 09:24 AM
nbame786's Avatar
nbame786
i'm not too worried....i have a vtec b16a engine i'm going to drop in during the spring....but i just wanted to know for now :smile:
ludedude
Aug 10, 2015 07:16 PM
Aug 10, 2015 01:59 PM
Accessory Products
Aug 10, 2015 01:35 PM
Aug 10, 2015 01:33 PM
