ERA mini Turbo restoration
Old 10-02-2017, 01:12 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
Hi..I have just purchased this ERA mini Turbo R1036 its ben sat in a garage for 13 years.
First time out of the garage since 2004
a quick dusting
and a rinse
the only interior problem is the drivers seat
but I managed to source these from the UK from a chap that did the leather conversion
the original mileage
the plan is is to get it home from the previous owner and remove the engine and sent it to the UK for a full rebuild and strip the shell back to bare and a full repair and respray
Old 11-17-2017, 01:57 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
I have finally paid for the ERA and collected it from the Previous owners home
had to use a Hiab as conventional ways were no good as spoiler was too low
20 minute trip to new home
landed safe
park up till I dump estate to make space
then the full stripdown and rest will begine including engine and turbo
Old 11-24-2017, 06:27 PM
f86sabre's Avatar
f86sabre
f86sabre is offline
Impressive!
Old 04-01-2018, 04:55 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
Hi..Peeps I have finally managed to find some time to make a start on the strip down of my ERA and what a pig getting the two front wheel arch and spoiler combo and its not great work by the people that made it looks like 2 different workers on the production line the front panel wheel arches are cut different
Old 04-01-2018, 04:59 PM
DneprDave's Avatar
DneprDave
DneprDave is offline
You should do the engine yourself, they are a perfect beginner's motor to rebuild.
Old 04-02-2018, 11:11 AM
mk1leg's Avatar
mk1leg
mk1leg is offline
I do usally build my own engines but I want this professionally done as this is going to be the best mini I have ever owned
Old 04-02-2018, 11:15 AM
mk1leg's Avatar
mk1leg
mk1leg is offline
Managed to get the rear spoiler and arches off whilst dodging the rain drops I would say that these ERAs were hasterly put together they must of used a BRG mini with std arches as they have left the old rivets in over the rear arches and as for soposed 8 body kit support brackets mine only has 4 and very rusty rear valance
Old 04-13-2018, 12:09 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
Whilst the sun was out late afternoon I managed to get the ERA interior out and bagged to stop it getting damp or dirty
and as for garages with post lifts the damage they cause....need tosort this before its painted....lol
Old 04-16-2018, 08:39 AM
MINIdave's Avatar
MINIdave
MINIdave is offline
Wow, this is a Project with a capital P. Still, I'm glad to see you restoring such a rare car, and it will go like the clappers once you're done with it. Please keep documenting your progress here......do you plan to take it down to bare metal or just patch the holes and give it a respray?
Old 04-16-2018, 02:26 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
I removed the dashboard and console the dash is held with 3 screws
the console has 4 self tappers hitten under the tunnel carpet
removed door cards and rear bins and cards
then I gave these parts a good scrub clean
I removed the speedo and thaco and backplate as there has surface rust
sanded then and primed and apply a satin black
Old 04-17-2018, 03:04 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
gauges and backplate refitted to dash
Old 04-29-2018, 12:59 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
I managed to remove the engine and remove all the parts in the engine bay
gave it a quick power wash before I send it to the UK for a full rebuild
removed heat shield
Old 09-06-2018, 01:04 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
a bit more done to the ERA rear valance removed
also removed the front panel
just the front scuttle to remove its the worst rust affected panel also the trickiest to do without removing the wings (fenders)
Old 10-11-2018, 12:28 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
more done on the resto
the worst job so far removing the glue fron sound deadening
front scuttle removed the glass to assess the damage
Old 04-05-2019, 01:16 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
sorry for the delay in progress as the weather here in the UK has been wet over the last few months and I'm restoring it under a tarp NO Shed or Garage so bare with me lol
Sent My engine to the UK for a rebuild as it was sat still for 14 years .
arrived at builders 4.4.18
inspection
turbo test fit
clean, rebore and paint
new rods and pistons
start of rebuild
bespoke manifold
Old 04-07-2019, 03:21 PM
MINIdave's Avatar
MINIdave
MINIdave is offline
Wow, that's going to be fantastic when done, can't wait to se more!
Old 04-14-2019, 10:32 AM
mk1leg's Avatar
mk1leg
mk1leg is offline
did a bit more on this sunny day cut out rust from scuttle and test fit repair
still a little fettllng to do.
and test fit genuine front panel drivers side ok
front ok
passenger side needs re jigging to fit
Old 05-10-2019, 12:41 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
a bit more done on the motor rebuild in the UK
in the final stages he tells me
AZdsrt (05-10-2019)
Old 05-10-2019, 05:45 PM
AZdsrt's Avatar
AZdsrt
AZdsrt is offline
That is really cool, thanks for posting.
Old 12-03-2019, 01:54 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
Back on my feet after hip replacement so I decided to do a full heritage scuttle replacement leaving the wings in place
I hope this works
also the motor has had all pipework completed and noe ready for a bench dyno set up and run-in
The following 2 users liked this post by mk1leg:
Andy_S (12-03-2019), Jimmy-R56s (12-16-2019)
Old 05-19-2020, 12:36 PM
mk1leg's Avatar
mk1leg
mk1leg is offline
Hi..Peeps ERA update progress so far see link
https://app.photobucket.com/u/mk1leg...4-31114be608c8
Old 06-11-2023, 06:59 AM
mk1leg's Avatar
mk1leg
mk1leg is offline
good day peeps so I have finally finished My ERA turbo on 3/6/2023
if you want to view progress pics please look here
Old 06-11-2023, 10:07 AM
MINI-MadMan's Avatar
MINI-MadMan
MINI-MadMan is offline
Nice work. Looks like you've given it a proper refresh inside and out. Happy motoring.
Old 01-31-2024, 04:20 AM
Matthew_Graham's Avatar
Matthew_Graham
Matthew_Graham is offline
Looks like you'll make a real monster out of him.
Old 02-17-2024, 09:40 AM
MINI-MadMan
Her
GreekDrifter91
Off-Topic :: Autos
14
12-01-2013 07:26 PM
Motor On
MINI Camera and Video
20
02-20-2008 10:13 PM
MaxN
Off-Topic :: Autos
19
10-01-2007 12:59 PM
Quick Reply: ERA mini Turbo restoration
