Engine and trans oil
Old Oct 16, 2016 | 10:22 PM
Martin Brenneke's Avatar
Martin Brenneke
Is it necessary to use 20-50 wt oil in classic or can a lower viscosity oil be used? Would lower wt oil make trans hard to shift and grind when putting in gear?
Old Oct 16, 2016 | 11:26 PM
Mini Mania's Avatar
20w-50 should be just fine!
http://www.minimania.com/part/5492GF...Semi-synthetic
Old Oct 17, 2016 | 08:34 AM
MINIdave's Avatar
MINIdave
I ran 10-40 for a while in the winter, but the car prefers 20W50. The more important thing is to find oil with the right quantity of zinc in it to protect the camshaft.
I buy Brad Penn oil from my local oil distributor, I pay about $6.50 qt in a case of 12, that gives me two oil changes and 2 spare bottles.
Old Oct 17, 2016 | 02:31 PM
mk1leg's Avatar
mk1leg
the classic mini Aseries and A+ engine is designed to only use 20/50w oil because of the engine and gearbox share the same oil thinner oils will only cause faster ware in mains and bigend and oil pump
Old Oct 17, 2016 | 03:52 PM
MINIdave's Avatar
MINIdave
Like I said, when I ran it it was COLD out - as in 20-30 degrees F (-6 to 0 C), when it warmed up I changed over to 20W50 and ran that from then on.
Old Oct 18, 2016 | 01:06 PM
Capt_bj's Avatar
Capt_bj
you can by "regular" oil and get a zinc additive
I use this
Oct 22, 2016 01:31 PM
ThirteenthCurve
Oct 18, 2016 09:18 AM
OutMotoring
Oct 13, 2016 08:56 AM
Oct 10, 2016 04:33 PM
Classic Mini Talk
Oct 10, 2016 04:10 PM
